Home > General > Vehicle lean when cornering
idi
Had this appear on the dashboard today. Drove on the motorway with it on for about an hour and all seemed normal.
Not had a chance to read the error codes yet, but what is the usual solution for this?
Post #603943 Sun Aug 30 2020 10:21pm
Disco_Mikey
The usual solution is to read the codes first to see whats causing the warning to come on...
Post #603946 Mon Aug 31 2020 5:32am
Eaters
Also, does it re-appear if you switch off and leave it for half an hour then restart? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #603949 Mon Aug 31 2020 7:56am
idi
The error was on all day yesterday even though I left the car for a few hours between starting.
However I started it this morning and the error has gone. I'm sure it will be back though
Post #603963 Mon Aug 31 2020 12:55pm
Eaters
The reason I ask is that I occasionally get an error message regarding suspension or special programs. It doesn't seem to affect handling for day to day road trips. And if I leave it the error does not re-appear for a while. The best theory I have had is that you shouldn't turn on the ignition and then try to start it. Count to 5 then start. This seems to reduce the incidence of the error.
Of course the best thing to do is to get the codes read as previously said but in the past no codes have been stored for me Robin
Gone:
MGZTT 190 2.5
Post #603964 Mon Aug 31 2020 1:01pm
idi
Got the codes read today and there is no error codes stored. I didn't know its possible to have an error appear but have no codes stored.
I'll try your advice in the future when it comes back. Are you saying turn on the ignition, wait 5 secods and then start the car?
Post #603968 Mon Aug 31 2020 4:55pm
Eaters
Yes. That’s it. My theory (totally unproven) is that it doesn’t like being started until it’s had a chance to get all the electrics fires up. So ignition on, wait till the display shows it’s done it’s self checking thing (about 5 seconds) Then you can start. I’ll be interested to know if it improves it for you. Robin
Gone:
MGZTT 190 2.5
Post #603973 Mon Aug 31 2020 9:18pm
mgrover
does it have ACE? if so is the fluid running low
Post #604147 Fri Sep 04 2020 3:48pm
idi
It has ACE. The fluid level is slighly above maximum. It hasn't happened since
Post #604151 Fri Sep 04 2020 6:34pm
idi
This error appeared again today. Still no error codes stored and ACE fluid is at the maximum line.
Any ideas what this could be?
Post #604868 Thu Sep 24 2020 5:08pm
Disco_Mikey
Need the fault codes read first..
Post #604870 Thu Sep 24 2020 7:30pm
idi
As above, I've had the fault codes read and there isn't any stored
Post #604878 Thu Sep 24 2020 8:48pm
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
What diag system did they use?
You may need something LR specific as some tools can't read all the systems properly.
Post #604881 Thu Sep 24 2020 10:08pm
idi
Took your advice and tried with a different reader today and got the following codes:
C1B11 - Pressure Control Valve
C1B03 - Direction Control Value
I reset the codes and started the car again and only C1B03 appeared the second time.
Post #604901 Fri Sep 25 2020 11:17am
