Home > Maintenance & Modifications > Engine System Fault uphill |
rob cupples Member Since: 27 Jun 2018 Location: Stirling Posts: 30 |
I had similar on my TDV8. Turned out to be hairline cracks on drivers side inlet manifold causing loss of boost pressure. I identified mine by seeing light oil misting around the area as well as spraying a bit of water on and seeing bubbles with engine on. Could be several other things though such as turbo boost hoses, turbo actuator etc. if you see nothing obvious you'll need the codes reading. |
Thu Jun 11 2020 7:15pm |
IggyIggins Member Since: 11 Jun 2020 Location: Sussex Posts: 16 |
Funny you mention it, the manifold on this side was replaced before the car was sold. It also threw up "manifold absolute pressure" on a code reader yesterday but not sure if that was historic or current, I'll have to check. I appreciate your help, I feel like such a mug right now |
Thu Jun 11 2020 7:19pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
It does sound like a cracked manifold. It's a common problem.
Thu Jun 11 2020 7:52pm |
Sometimes you'll see the crack if you look carefully and spray some water on with engine on you might see bubbles. Failing that a pressure test or smoke test |
Thu Jun 11 2020 8:03pm |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 |
The exact symptom and circumstance that I had.
Thu Jun 11 2020 9:20pm |
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 |
I know you've opened the bonnet and checked the top intercooler hoses but my split was on the underside and when I did the same initial inspection it wasn't visible at all, even though the split was 2 inches in length.
Fri Jun 12 2020 10:31am |
Thanks so much for the replies, guys.
Sun Jun 14 2020 12:41am |
Did you replace it yourself? How easy is it? I've done rocker cover replacements on big BMW engines before but I'm not a mechanic, though if it's do-able I'd have a pop. LR indie want over £1000 to do it. I'm just concerned about the total lack of space under there. I have big hands |
Sun Jun 14 2020 12:44am |
I have a friend who's a mobile mechanic and we did it together, it's fiddly and you will inevitably break a couple of the pipes that have to be removed (I'd read that that was likely so had already bought them, just in case) but it's a fairly straightforward replacement, access is limited in parts though, so if you really do have a couple of plates rather than hands you may have to draft in a small child to assist lol.
Sun Jun 14 2020 8:19am |
