Home > Technical > Crankshaft seal leak
GARYF123
Hi, in June 2016, my RRS 2007 TDV6 had a recon engine fitted by NWS Motor Services at 123,860 miles.
In January 2019 at the annual service (135,204 miles), it was reported to have a oil leak from either oil pump or crankshaft oil seal. This was at Maltings off road Ltd in Doncaster.
I booked it in for 15/02/2019 and duly had the oil seal replaced at a cost of £398.72 inc. vat. They stated that the original oil seal had been pressed in too far?
All was well until i took it back in January 2020 for annual service. They told me all was well but there 'seemed' to bit 'a bit of oil residue' around the crank oil seal but they were not sure if it was a leak or if the mechanic had not cleaned around it when fitted previously. I explained that it should not be leaking 11 months and 1687 miles later?
He told me to keep a eye on it!
As it is not possible to see the seal properly whilst vehicle is on the ground and not been using it, with the present situation giving me some time to spend on car, i removed the metal engine shield from underneath and found the crank seal to be weeping quite badly.
Before i go back to them, have i got any comeback in your opinions?
Thanks in advance,
Gary.
Post #597097 Sat Mar 28 2020 12:17pm
Disco_Mikey
New pump and seal required. There was a batch of oil pumps leaking from the hex screw in the casing a few years back
Assuming that it's not a cam seal leaking, and the nose of the crank is alright...
Post #597103 Sat Mar 28 2020 2:37pm
GARYF123
Hi Mikey, you have replied to my later post about me having a go at replacing oil seal/pump myself. However, my Indy has clouded the issue a little by suggesting that it would be highly improbable for 2 genuine LR seals to be faulty and his guys have changed hundreds of these with no problems as you would expect from experienced mechanics. He completely ruled out faulty pump but he suggested there were a few possible scenarios with the breather being one and the worst case scenario being a excessive end float in crankshaft 😭. To be honest, if that was the case, I couldn’t justify that spend so I would class it as terminal.
What are your (or anybody’s) thoughts?
Gary.
Post #598081 Fri Apr 24 2020 8:28am
GARYF123
Any ideas where crankcase breather is on 2007 TDV6 and how to clean it please?
Post #598088 Fri Apr 24 2020 1:47pm
Hahaha
It’s behind the oil filter
A nightmare to squeeze out.
I don’t think they get blocked on these
Post #598092 Fri Apr 24 2020 3:12pm
GARYF123
Ok ta!
Any more ideas as to how excess pressure could build up to blow seal or any other suggestions?
Post #598096 Fri Apr 24 2020 6:55pm
Disco_Mikey
If its a Chinese special pump, they have been known to have issues
There was a single batch of genuine LR pumps that had a non-sealed gallery, causing a leak
I'd be inclined to put an OEM/Genuine pump and seal on this time round. If it works, all well and good.
If it doesn't work, then there can only be an issue with the crank sealing surface...
The above obviously assumes that the cam seals are not leaking Thumbs Up
Post #598097 Fri Apr 24 2020 7:00pm
GARYF123
Well I got underneath today and removed the 2 steel trays. Fair bit of oil but I am not convinced it is coming from the front crank seal. A bit wet maybe and the hole in the oil pump directly behind the crank pulley showed Signs of oil but not sure if was cleaned up properly after last years seal replacement. It seems to be around the sump area and transmission box although it would as these are the lowest points. I took some pics to see if anybody could offer any advice?
Post #598138 Sat Apr 25 2020 5:51pm
GARYF123
The pics are in my gallery!
Post #598139 Sat Apr 25 2020 5:56pm
Disco_Mikey
Its difficult to say
In one pic, the drain hole in the belt cover looks dry, and in another it looks wet
Can you wash the residual oil off, and run the engine with the covers off?
Post #598141 Sat Apr 25 2020 6:13pm
GARYF123
The hole has definitely got some oil in (what does this hole do?) I have wiped it all clean and have left it in air on stands without the guards on so I can leave it running for a bit and check it. The problem is actually seeing where it comes from. I remember spending ages trying to identify a leak 3 years ago and it turned out to be intercooler hose. Could it be rear crank seal?
Mikey, I think you should be relocated to Yorkshire!!!
Post #598143 Sat Apr 25 2020 6:32pm
erickwan
Malaysia
If you want cheap, go buy yourself a Ford or Citroen-Peugeot oil pump and crank seal. They are originals to this engine.
Post #598332 Thu Apr 30 2020 7:29am
