Home > Technical > Crankshaft seal leak |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 |
Hi, in June 2016, my RRS 2007 TDV6 had a recon engine fitted by NWS Motor Services at 123,860 miles.
Sat Mar 28 2020 12:17pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
New pump and seal required. There was a batch of oil pumps leaking from the hex screw in the casing a few years back
Sat Mar 28 2020 2:37pm |
Hi Mikey, you have replied to my later post about me having a go at replacing oil seal/pump myself. However, my Indy has clouded the issue a little by suggesting that it would be highly improbable for 2 genuine LR seals to be faulty and his guys have changed hundreds of these with no problems as you would expect from experienced mechanics. He completely ruled out faulty pump but he suggested there were a few possible scenarios with the breather being one and the worst case scenario being a excessive end float in crankshaft 😭. To be honest, if that was the case, I couldn’t justify that spend so I would class it as terminal.
Fri Apr 24 2020 8:28am |
Any ideas where crankcase breather is on 2007 TDV6 and how to clean it please? |
Fri Apr 24 2020 1:47pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Hahaha
Fri Apr 24 2020 3:12pm |
Ok ta!
Fri Apr 24 2020 6:55pm |
If its a Chinese special pump, they have been known to have issues
Fri Apr 24 2020 7:00pm |
Well I got underneath today and removed the 2 steel trays. Fair bit of oil but I am not convinced it is coming from the front crank seal. A bit wet maybe and the hole in the oil pump directly behind the crank pulley showed Signs of oil but not sure if was cleaned up properly after last years seal replacement. It seems to be around the sump area and transmission box although it would as these are the lowest points. I took some pics to see if anybody could offer any advice? |
Sat Apr 25 2020 5:51pm |
The pics are in my gallery! |
Sat Apr 25 2020 5:56pm |
Its difficult to say
Sat Apr 25 2020 6:13pm |
The hole has definitely got some oil in (what does this hole do?) I have wiped it all clean and have left it in air on stands without the guards on so I can leave it running for a bit and check it. The problem is actually seeing where it comes from. I remember spending ages trying to identify a leak 3 years ago and it turned out to be intercooler hose. Could it be rear crank seal?
Sat Apr 25 2020 6:32pm |
