Home > General > Using headlight LEDS as DRL |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
No, can only be done in conjunction with dipped headlights using the IID tool, although I believe others have done it via the fusebox by bridging the sidelight fuses somehow. Sure someone will post a link to how they manged to do it.
Wed Mar 25 2020 2:32am |
I’ve done mine so that as soon as the car unlocks, the front and rear LED sidelights come on. If the car isn’t accessed in about 5 minutes they then switch off so they’re not left to drain the battery. I just used 4 brake out fuses, 2 pairs wired to a 4 pole on/off switch (so I can turn them off it goes to a garage).
Wed Mar 25 2020 3:54am |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 |
See this topic:
Wed Mar 25 2020 12:01pm |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 |
Done exactly as Brit Plumber says, bridge the fuses and LEDs come on when you unlock the car and stay on, then go off when you lock the car.
Wed Mar 25 2020 8:44pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
As above, just bridge the connections in the fuse box.
Wed Mar 25 2020 9:05pm |
