Home > General > Tow Bar or not Tow Bar??? |
Sit Member Since: 14 Jun 2015 Location: Bristol Posts: 208 |
So this might be a daft question but all RRS fitted with a tow bar receptacle? A couple I have called about when asked have said no tow bar, however I can just buy the Swan neck part off eBay.
Fri Sep 13 2019 7:15pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
They all have the hole
Fri Sep 13 2019 8:15pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
There are quite a few posts about the removable tow bar and there was a recall because of wear and subsequent failure.
Sat Sep 14 2019 7:56am |
What's in the fridge? Member Since: 14 Aug 2019 Location: Nearest hedge to London Posts: 112 |
Hi just in case you want to check if the sport your looking at (presume) earlier rather than the latest model has the electrics already in it's easy to remove the panel (@2m20s into video), just go steady on the older ones as ahem easy to snap the screws as can go brittle and cost a whopping £1.29 a pair to replace, er a um friend had to replace theirs.
Sat Sep 14 2019 11:11am |
Thanks for posting the video, a picture is worth etc. I confess I haven't test fitted mine although I did find it didn't have the red plug when I looked (actually cheaper from my local LR parts dept than ebay!)
Sat Sep 14 2019 11:54am |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
The best bit about that video is that it's a great demonstration of when it isn't in properly (the first few times) - and credit to them, they didn't edit that bit out so we can actually learn Good vid.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Mon Sep 16 2019 8:05am |
That’s a REALLY useful video thanks for posting, interesting to see if you weren’t aware of that red collar disappearing completely you could be forgiven for thinking it was fitted properly.
Mon Sep 16 2019 8:17am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
Yes it is amazing what you learn if you read the actual instructions which cover all this. 07MY RRS TDV6
Mon Sep 16 2019 8:21am |
