Home > Technical > Should liquid gasket be used fitting water pump? No.
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
I'm about to change water pump, there's a steel gasket with it but as-
per tittle should liquid gasket be used fitting water pump, together with steel gasket?
Tempted to use both but anyone with experience on that?
Pump is called Pro-Flow btw.
Answering this myself, no just used the compressible metal gasket and all good, no leaks.
Post #585767 Fri Aug 23 2019 11:56pm
erickwan
Malaysia
Steel gasket?
I thought it sealed using an o-ring.
Post #586445 Fri Sep 06 2019 11:53am
rover75
Only the dervs
this type: https://rimmerbros.com/Item--i-4575902
https://rimmerbros.com/Item--i-4575902P
Post #586451 Fri Sep 06 2019 6:14pm
