Home > General > OBD |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
If you want cheap or value for money. you could buy one of these.
Sat Jul 13 2019 4:43pm |
You need one that reads the whole code not just the generic code. This can then be x-ref’d to the workshop manual which I’ve found invaluable in fault finding. Saved me a lot of time fault finding on my RSE and nailed it in minutes. 2019 5.0 SC SVA (Current)
Sat Jul 13 2019 9:49pm |
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 |
Andy thanks for the link to EBay.
Sat Jul 13 2019 10:18pm |
The thing with ELM327 is that it’s not a device, it’s a standard. So dozens of tools use ELM327 but not all are equal. Some will clear faults but not give detailed DTCs, some will give good DTCs for the engine and nothing else. They are a bit hit and miss until you try them out. 2019 5.0 SC SVA (Current)
Sat Jul 13 2019 10:38pm |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
just as well buy the right tool first, gap or similar that does it all, makes it keep after first fault or two. (unless your mate has one you can borrow) |
Sat Jul 13 2019 11:00pm |
Thanks for the advice re what OBD reader to buy.
Wed Jul 17 2019 12:05pm |
Bruster400 Member Since: 12 Jun 2019 Location: Manchester Posts: 15 |
Hi all,
Thu Jul 18 2019 1:50pm |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 |
P.M sent |
Fri Jul 19 2019 6:04pm |
Just thought I'd update on my cheeky request to borrow an OBD reader.... I now have one of my own!!
Tue Jul 30 2019 8:17pm |
