Home > Maintenance & Modifications > Steering wheel airbag
Wayneclarke
Hi Guys, purchased a used airbag which looks in great condition apart from a plastic pin which has snapped off, i was due to have this fitted tomorrow along with my steering wheel re-trim, My question is will this cause a problem or will it be ok???
Post #583505 Thu Jul 04 2019 8:06am
Brit Plumber
I assume someone else is fitting it for you or else I’d fit it but raise an issue with the seller for a replacement. I don’t see it being an issue however it is an airbag system so I wouldn’t stake my reputation on it. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #583511 Thu Jul 04 2019 11:02am
Wayneclarke
yeah the company that is doing my steering wheel which is a company a couple of people on here have used i believe is doing it, suppose theres no harm in trying to fit it and see what happens. i was thinking maybe i could take the back part of mine and replace the new one thats broke, but then thats only if the back comes apart.
Post #583514 Thu Jul 04 2019 11:19am
