Home > General > Suspension issue with codes. Electrical or compressor? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
yes you could use that bulb.
Sat Apr 27 2019 2:12pm |
Silverman Member Since: 25 Apr 2019 Location: London Posts: 30 |
Ok I done that mate.
Sat Apr 27 2019 2:38pm |
that sounds good that the compressor makes a noise.
Sat Apr 27 2019 2:42pm |
Ok. My impatience kicked in and I drove to Halfords to get a fuse!
Sat Apr 27 2019 4:09pm |
Pipe leaking by compressor ?
Sat Apr 27 2019 5:24pm |
I’ve done a bit more reading about the recent code, I didn’t realise the compressor was a wear item. I’m nearly at 120k miles now so even if it’s not the fault throwing the code it’s likely due a change anyway. Also I plan to sell the car in the next 6 months as I’ve had it over 6 years, it will be a nice thing for the next owner to see it’s been replaced regardless.
Sat Apr 27 2019 7:35pm |
Hitachi are the original make. If you can get one of them that is fine. Or Dunlop
Sat Apr 27 2019 8:12pm |
Ok this now got strange.
Sun Apr 28 2019 11:16am |
I am not completely surprised this happened.
Sun Apr 28 2019 2:37pm |
Really? I’m very surprised
Sun Apr 28 2019 3:35pm |
Has the yellow dash light been on for weeks? |
Sun Apr 28 2019 5:37pm |
Yes. I ignored it as it still seemed to work ok going up
Mon Apr 29 2019 7:35am |
Drove it today and within 5 minutes the yellow light come back and usual dash warnings. It was always too good to be true.
Mon Apr 29 2019 12:25pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
Slow filling is pointing to the compressor needing to be replaced. 2012 SDV6 - it's missing a couple of cylinders
Mon Apr 29 2019 2:26pm |
