Home > Technical > Suspension issue
M9G UK
Suspension issue
I knew I would get one of these one day. So the rear of my car seems to drop at different levels sometimes and stays different and raises at different speeds. The nearside rear seems to drop lower than the offside. I can also here what I believe to be a compressor pump at the rear on the nearside constantly turning on and off. I don't know if its also connected but my rear nearside wheel, hub etc etc seems to be covered with what I though was brake dust but thinking now could this be rusty water being blown out of a possible air leak in the compressor system? as its the same corner as the one that drops the most.
I can get them to be level at the back in normal driving mode but as i say the compressor keeps turning on and off almost like its compensating for air loss
Any thoughts on this please? 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Xtrons Android head unit
Smile
Post #578582 Sun Apr 07 2019 7:43pm
gogsy1956
Your right,, the compressor is located by the rear nearside passenger door. I wouldn't have thought the system would be throwing out rusty water as it has its own filter dryer on the end of the compressor but their is still a good chance you have a leak. I would go armed with some soapy water in a spray bottle and work along the pipes as best you can to see if you can spot any leaks. Some of the early compressors suffered from cracked end plates but you will have to remove the cover from the bottom of the compressor to get a look at it. Other than that the valve blocks sometimes stick causing issues, this is located on the rear axle I think,, it can be cleaned and serviced if your handy with spanner or two. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #578588 Mon Apr 08 2019 5:25am
M9G UK
OK thanks, somewhere too start. Thinking about it over night something sticky sounds feasible as I have this morning noticed that over night the corner hasn't dropped and is still at the same height as the other side so would almost like to rule out a leak as would think the one side would drop if there was a leak? 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #578590 Mon Apr 08 2019 5:56am
gogsy1956
Sounds logical,, if you had a leak on one corner it would always drop at that side I think. 2010 RRS, TDV8
22" overfinch
Post #578592 Mon Apr 08 2019 6:27am
They self level when parked (drop down).
You can remove a fuse under the bonnet to prevent this, so you can see what corner really has the problem/leak
Post #578612 Mon Apr 08 2019 11:05am
M9G UK
ah right ok i'll try that, Is it fuse number 3? 5 amp?
I have just noticed while out there that the distance between top of tyre and wheelarch is about an inch less on the nearside rear 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #578626 Mon Apr 08 2019 3:26pm
It is a small 20A yellow fuse under the bonnet
Post #578630 Mon Apr 08 2019 5:14pm
M9G UK
Thumbs Up Thumbs Up Thumbs Up 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #578631 Mon Apr 08 2019 5:22pm
M9G UK
Fuse 26 then. I did do a search on here and saw a suspension issue and the guy removed fuse number 3 which was a 5amp so thought it was that one.
After removing number 26 I don't have to start it up and back off again or anything do I? 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #578633 Mon Apr 08 2019 5:27pm
You ensure the car is at a decent high height, i.e it has recently been driven.
THen remove the fuse.
And leave over night.
Inspect/measure heights in the morning to see if any different to normal
small one
Post #578634 Mon Apr 08 2019 5:31pm
M9G UK
Cool thanks yep number 26 Thumbs Up Very Happy
Just measured from top of rim to wheelarch
Offside 184mm
Nearside 165mm
Already a difference of 19mm so see what it is in the morning 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #578635 Mon Apr 08 2019 6:06pm
M9G UK
OK so following morning, although a slight difference to begin with last night and the removal of fuse 26 this morning there is no difference in the heights, both exactly the same so guessing no leaks.
So is my next investigation the valve on the rear axle?
Cheers 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #578646 Tue Apr 09 2019 5:54am
either you removed the wrong fuse
or the strut and valve block are fine.
or the car wasn't high enough to start with
Post #578657 Tue Apr 09 2019 11:07am
M9G UK
It was in the normal drive mode when I parked up and the fuse was the 20amp yellow one as in your picture 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #578670 Tue Apr 09 2019 2:59pm
M9G UK
Ok so im trying this again. I have had the engine running and have put the suspension right to the top then right to the bottom then back into the driving height, removed fuse 26 and I also removed fuse 3 which has the same logo as the 26 and ive now left it.
One thing, should I have removed the fuses before switching the ignition off or whilst the engine still running?
Smile
Post #578680 Tue Apr 09 2019 7:12pm
