Home > General > Uneaven revs and juddering
Black dog
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Experiencing a bouncing rev counter and juddering when driving . Revs keep jumping between 1500-2000rmp. Sometimes judders when going up a small incline.
Had a new belt and full service recently.
Advanced fails code detected a valve not closing recommended some engine flush which I have done but it's no better.
Any suggestions please.
This is my first post, RRS 2008 hse
Thanks
Post #540682 Sun Nov 12 2017 9:33pm
Torque converter possibly. 2012 SDV6 - it's missing a couple of cylinders
Post #540686 Sun Nov 12 2017 10:22pm
Bodsy
Site Sponsor
Usually torque converter, especially if worse going up an incline.
Could also sometimes be egr sticking a bit Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #540690 Sun Nov 12 2017 10:42pm
drdelrrs
You could try a brief 'stall' test.
Left foot hard on brakes. Car in drive and throttle progressively and see if the torque convertor/transmission 'holds' the engine in stall conditions. Should be no noises, slippage etc.
Make sure you have plenty of clearance in front of the car and you'll need to have a firm pressure on the brakes.
Do not hold the engine in stall for more than a few seconds. If you get noises it can be the transmission's brake bands. Failure to hold the engine revs stable points to convertor.
Might be worth a look underneath to see if any fluid has leaked
Post #540743 Mon Nov 13 2017 10:30am
Baz0195
England 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi there, I know this sounds like a silly question but where would the leak be coming from if there was one as mine has the same issue but between 2000 & 3000 revs Sad
Post #577180 Sat Mar 16 2019 5:33pm
