Home > Technical > Looking for the L320 2010/2012 wiring diagrams |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
What circuit are you on? are those numbers meant to be sj2006 and sj2007? can find the numbers in a few plugs, but just doesn't show where they terminate, just gives destination as sj2006 or sj2007.
Sun Jan 13 2019 11:47pm |
Hi Col, it is SJ2006 and SJ 2007 and it’s the surround camera system. I’ve got the wiring maintenance manual which shows the connector, contacts and destination but the wiring diagram manual I bought with the maintenance manual is for the 05 to 09 car which is of no use. The diagram gives a distance in mm along the wire to where the SJ is from the connector. Which other systems did you find with these joints? It may help locate them, I tried searching the wiring maintenance manual but obviously doesn’t search the diagram, only the titles as it didn’t find any. 2019 5.0 SC SVA (Current)
Mon Jan 14 2019 10:01am |
The one's I have just shows plugs and destination as well, they are shown on the parking module and header connectors behind n/s panel in boot, tailgate harness under headlining at top of the tailgate, camera module under drivers seat and also a couple of plugs under centre console. A 6 pin white connector C1000 which they call header-connector behind the l/h panel in the boot shows just soldered joint can bus connections in it, pin 1 is 2006 Y/W and pin 4 is 2007 Y/U if it's of any help.
Mon Jan 14 2019 10:31am |
Thanks Col, I shall do some invest.
Tue Jan 15 2019 9:07am |
devonsteve Member Since: 07 Nov 2018 Location: devon Posts: 1 |
hi where did you get the wiring diagram for the 2005 to 2009 rrs from, as I have a problem with my central locking not working
Wed Jan 16 2019 4:59am |
Chris, I have a Land Rover electrical reference library for the sport, consists of nearly 1200 pages which can be searched if you have a connector number etc. and comes up with location, wire colours, pin configuration and where wires go to etc. honestly can't remember where I got it from, sure I would off downloaded it online somewhere, will have a go and see if I can find it again.
Wed Jan 16 2019 6:11am |
