Home > Maintenance & Modifications > Service types for the elderly vehicles
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Folks
My MY07 RRS TDV8 is now due its 11 year service. I was quoted £438 (same as the 5 year service) from a main stealer today, but the member of staff said the type of service was a Minor Service as it was now in its 11th year, so they go back to the start. If this is the case should it not be in the region of £180, as priced on the same dealers web page and the price of the 12 month service?
Martin. Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #569386 Wed Nov 21 2018 5:50pm
Disco_Mikey
11 year service is an "A" service with no extras
£200 Thumbs Up
Post #569389 Wed Nov 21 2018 7:16pm
MartinsTDV8
Cheers Mike. Previously owned 1999 Disco 2 TD5
Post #569390 Wed Nov 21 2018 7:27pm
Eaters
Do you need to go to the main dealer for your car? I'd try and find a local independent LR expert as they often know better than the grease monkeys in the main dealers and their hourly rate should be a lot less. Presumably the car is not going to hold much if any extra value for being serviced by a main dealer. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #569426 Thu Nov 22 2018 8:32am
Brit Plumber
As above, mines 6 years old and it goes to a local independent staffed by Land Rover trained techs. In my opinion the value should increase because of it. They are also very fair as the quote for my SC was less than the TDV8 and the final cost was less than quoted. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #569444 Thu Nov 22 2018 12:55pm
MartinsTDV8
No it doesn’t need a main dealer sevice, but as I am at the end of the world up here, there isnt a lot of choice. Rolling with laughter Previously owned 1999 Disco 2 TD5
Post #569463 Thu Nov 22 2018 5:21pm
Tim in Scotland
Not even many main dealers up there as well! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #569467 Thu Nov 22 2018 5:33pm
Eaters
Haha - good point! Maybe someone on here has a tame "local" independent.
I know it looks like its about an hour away from you but are these guys any good?
http://inverness4x4-centre.co.uk/ Robin
Gone:
MGZTT 190 2.5
Post #569517 Fri Nov 23 2018 8:16am
MartinsTDV8
Sadly the Inverness 4x4 Indie also wants £500+ for this service, slightly dearer than the Main dealer: both are literally in the same street up here. Censored Previously owned 1999 Disco 2 TD5
Post #572595 Tue Jan 08 2019 12:20pm
Disco_Mikey
I have a customer who live a little North of Inverness, who used to use Inverness 4x4, until her engine imploded. She was quoted £14,000 to fit a 2nd hand engine into her D3 Shocked
And then they offered to buy it off her for £500 Rolling Eyes
Post #572617 Tue Jan 08 2019 7:25pm
MartinsTDV8
Sadly Mike, you are too far south for me, so I’m gonna go to the Dealers Big Cry Previously owned 1999 Disco 2 TD5
Post #572619 Tue Jan 08 2019 8:15pm
MartinsTDV8
Went into dealers - Parks Land Rover Inverness - mechanic traced fault to chaffed wire, replaced, tested, videod, and serviced. Total bill £385. Very happy Very Happy Previously owned 1999 Disco 2 TD5
Post #572874 Fri Jan 11 2019 8:38pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Not often Dundee is described as being too far south from anywhere, but then again I seem to hear "duelling banjo's" every time I go through there Mr. Green Mr. Green
Post #572913 Sat Jan 12 2019 10:22am
MartinsTDV8
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Previously owned 1999 Disco 2 TD5
Post #572923 Sat Jan 12 2019 1:08pm
Eaters
Just had a B service done on my 11 year old TDV8 at my local Indy. £512 including MoT and rear brake pads. Sounds OK to me. That includes a courtesy car for the day and, when they couldn't get the car through the MoT because of the stupid AFS headlight not aligning properly, instead of failing it they just fiddled around until it worked then called that pass! Robin
Gone:
MGZTT 190 2.5
Post #575293 Fri Feb 15 2019 10:49am
