Home > General > Suspension Fault / Suspension Refresh... (suspension idiot) |
RUSK Member Since: 27 Nov 2018 Location: South West Posts: 63 |
My garage said the fault code was compressor - I’m just thinking ahead about what the height sensors will cost and either bring ready to go that way if needed OR getting both done whilst they have it in.
Thu Dec 27 2018 4:10pm |
Antburgess89 Member Since: 27 Dec 2018 Location: Andover Posts: 23 |
I had my driver's side rear done from a local garage and charged me 1 hour labor. They said it took them 30mins to change but had to charge me for 1 hour .
Thu Dec 27 2018 4:14pm |
I've got a shiny new compressor ready to fit now, but still struggling with the ride height sensors...
Tue Jan 01 2019 10:19pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
What are the number of the one's you have, and are they 3 pin connector or 6 pin? although the should interchange.
Tue Jan 01 2019 10:46pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
Have a look on advanced motor factors.
Tue Jan 01 2019 10:48pm |
AAAAAAAAAAARGH...
Wed Jan 09 2019 4:57pm |
You need to check your VIN number and look on Advanced Factors web site..
Wed Jan 09 2019 5:43pm |
That's awesome, thank you... (and it was posted above buy I managed not to see it..! )
Wed Jan 09 2019 7:53pm |
I would suggest that you have the Hitachi compressor and not the AMK.
Wed Jan 09 2019 8:24pm |
I think you need to establish if you have a Hitachi or AMK compressor fitted first, on your Vin No. it should be a Hitachi unless it has already been changed previously, it is easy enough to tell the difference with the plastic cover removed as they mount totally different to the chassis, which is why the AMK kit is expensive as you need the new mounting bracket, new type relay for the fuse box, a software upgrade and even the plastic cover. If you already have a AMK fitted you don't need the full kit, just the compressor unit. L/R themselves no longer supply the Hitachi one. If you post a picture of the one currently fitted it is simple enough to tell you if it is AMK or Hitachi as said previously.
Wed Jan 09 2019 8:52pm |
This is the photo the mechanic took to get me the part number... can anyone tell which compressor it is from this?
Wed Jan 09 2019 10:55pm |
That is a totally obsolete part number so there is a very strong possibility it is the original Hitachi, the part number will eventually supersede to the AMK one I suspect, because as I said L/R themselves do not supply the Hitachi anymore. However you could try LR015303 or LR023964. Google the numbers and see what turns up Island 4x4 always used to be very good.
Wed Jan 09 2019 11:23pm |
I matched those numbers to the part I bought... I thought I'd got it nailed! |
Wed Jan 09 2019 11:34pm |
I think LR015303 may have superceded to LR023964 anyway.
Wed Jan 09 2019 11:40pm |
