Home > Maintenance & Modifications > Service types for the elderly vehicles |
MartinsTDV8 Member Since: 22 Feb 2017 Location: County of Sutherland. Posts: 140 |
Folks
Wed Nov 21 2018 5:50pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
11 year service is an "A" service with no extras
Wed Nov 21 2018 7:16pm |
Cheers Mike. Previously owned 1999 Disco 2 TD5
Wed Nov 21 2018 7:27pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
Do you need to go to the main dealer for your car? I'd try and find a local independent LR expert as they often know better than the grease monkeys in the main dealers and their hourly rate should be a lot less. Presumably the car is not going to hold much if any extra value for being serviced by a main dealer. Robin
Thu Nov 22 2018 8:32am |
No it doesn’t need a main dealer sevice, but as I am at the end of the world up here, there isnt a lot of choice. Previously owned 1999 Disco 2 TD5
Thu Nov 22 2018 5:21pm |
Not even many main dealers up there as well! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Nov 22 2018 5:33pm |
Haha - good point! Maybe someone on here has a tame "local" independent.
Fri Nov 23 2018 8:16am |
Sadly the Inverness 4x4 Indie also wants £500+ for this service, slightly dearer than the Main dealer: both are literally in the same street up here. Previously owned 1999 Disco 2 TD5
Tue Jan 08 2019 12:20pm |
I have a customer who live a little North of Inverness, who used to use Inverness 4x4, until her engine imploded. She was quoted £14,000 to fit a 2nd hand engine into her D3
Tue Jan 08 2019 7:25pm |
Sadly Mike, you are too far south for me, so I’m gonna go to the Dealers Previously owned 1999 Disco 2 TD5
Tue Jan 08 2019 8:15pm |
Went into dealers - Parks Land Rover Inverness - mechanic traced fault to chaffed wire, replaced, tested, videod, and serviced. Total bill £385. Very happy Previously owned 1999 Disco 2 TD5
Fri Jan 11 2019 8:38pm |
Not often Dundee is described as being too far south from anywhere, but then again I seem to hear "duelling banjo's" every time I go through there |
Sat Jan 12 2019 10:22am |
Sat Jan 12 2019 1:08pm |
Just had a B service done on my 11 year old TDV8 at my local Indy. £512 including MoT and rear brake pads. Sounds OK to me. That includes a courtesy car for the day and, when they couldn't get the car through the MoT because of the stupid AFS headlight not aligning properly, instead of failing it they just fiddled around until it worked then called that pass! Robin
Fri Feb 15 2019 10:49am |
