Home > General > Suspension Fault / Suspension Refresh... (suspension idiot)
RUSK
My 2008 TDV8 has flashed up the “normal height only” message, and my mechanic thinks it’s the compressor or “compressor system”. Would I be right in thinking that this could be any of the following:
Compressor?
Air bags?
Height sensors?
Fuses?
Assuming it’s not fuses, what would the likely cost of parts and labour be for a new compressor, new airbags and new ride height sensors? I’m thinking I could get it all done at once for “future proofing” rather than have them fiddle around for hours looking for which component is faulty.
Any way to tell which compressor I have without digging out the part itself?
Any decent suppliers for the above parts?
All advice welcomed. Thumbs Up
Post #571313 Tue Dec 18 2018 12:49pm
Themoog
Get the code reader on it first. Then go from there.
Post #571323 Tue Dec 18 2018 4:27pm
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Rusk - get your battery checked as well. Mine was dying slowly and started to switch of special programmes including adjusting heights. Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #571408 Thu Dec 20 2018 10:32am
Tim in Scotland
Also check that all your tail light lamps are working - a blown lamp at the back can throw up all sorts of warnings on the dash 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #571412 Thu Dec 20 2018 11:53am
Assuming fuses checked, the compressor and height sensors are the most likely cause. The sensors being the most likely of those two.
The airbags are pretty robust and very rarely cause a failure - they are much more robust than the old days of the P38 etc. 2012 SDV6 - it's missing a couple of cylinders
Post #571415 Thu Dec 20 2018 3:09pm
PC76
A tip is to check the 4*4 screen, it will show a small flashing red box if there is an issue with a particular corner. helps with fault finding if you don't have a code reader..
Post #571446 Fri Dec 21 2018 12:33pm
RUSK
Thank you for the help so far...
The only red flashing dot I can get on the 4x4 info screen is the front right wheel, if I lower the suspension to “access height” when I’ve just started the car up and the suspension fault warning hasn’t kicked in yet.
That same wheel was the one that had a slow puncture that I had to keep topping up with air whilst I waited for my new wheels and tyres to arrive - might that be related?
I wondered if that air bag was leaking but is it possible the constant topping up has scuppered the sensor on that wheel???
Post #571500 Sat Dec 22 2018 8:43am
PC76
Check the tyre make and size against the others.
Some manufacturers are actually quite different in size. This cause the ecu to get messed up as it thinks it’s continually going round corners lol and is free to do!
Post #571502 Sat Dec 22 2018 9:36am
RUSK
Identical Pirelli Scorpians on all wheels... previously identical Nexxens on all wheels BUT the offending wheel was the one that had a slow puncture.
Post #571503 Sat Dec 22 2018 10:16am
PC76
Ok I would check tyre pressures, then measure the height of the suspension using a tape measure from the underside of the wheel arch to the top of the center hub cap. (For calibration purposes it’s measured to the center of the cap)
In normal operation the ecu allows up to a 10mm difference before adjusting, anything greater than 10 mm COULD indicate its out of calibration. I’m out now and can’t remember the measurement for the front. If you google gap IID tool the instructions book contains the required measurements.
Take the measurements once you have moved it approx 5 meters and are on level ground with the engine running.
The next thing to do would be a hard reset of the car. Disconect the battery for ten minutes. Remove both pos and meg terminals. Before reconnecting short the two leads together, this discharges any remaining current. You will need to reset the radio etc but this clears all faults from the ecu memory. If it comes back then you do have an issue. If it doesn’t then mines pint 🍺
Without a code reader there is no more you can do. I fully recommend either having a good friend with one or for approx £400 the Gap IID tool is the one to get.
Post #571517 Sat Dec 22 2018 2:13pm
RUSK
Happy to do a hard reset... but I don’t seem to have a radio code...
Will a hard reset cause any other issues?
Post #571519 Sat Dec 22 2018 2:19pm
PC76
There is no radio code, just need to reset date, time, and radio stations memory.
No other issues..
Post #571520 Sat Dec 22 2018 2:31pm
RUSK
And touching the battery cables together won’t Censored up the electrics!?
Post #571556 Sat Dec 22 2018 10:27pm
TubaPlayer
No it won't Smile 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #571559 Sat Dec 22 2018 10:34pm
RUSK
Did this today - exactly as above, but it doesn’t shift the fault - so looks like a new compressor... BUT, can anyone give me an idea of the labour time on replacing the ride height sensors?
And, is recalibration after fitting likely to be something only a main dealer or specialist can do?
Post #571798 Thu Dec 27 2018 3:20pm
