Home > Maintenance & Modifications > Strange feeling from the engine on start up.
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Folks
Sometimes when I start the car and select either D or R the car feels like it is juddering.
I took it out of gear and put it into N and it feels like it an engine issue, as the car vibrates.
As soon as I accelerate, it goes away, and it doesn’t happen every time.
Any ideas? Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #567369 Sun Oct 21 2018 11:30am
PC76
Does it sound like the engine is running smoothly or miss fire?
do you have an IID tool?
Post #567370 Sun Oct 21 2018 11:56am
MartinsTDV8
Feels like a misfire, and I have a Hawkeye. Previously owned 1999 Disco 2 TD5
Post #567371 Sun Oct 21 2018 1:52pm
PC76
Possibly an injector issue.
With the 2.7’s I believe you can see the injectors you maybe able to chart them and see if any are behaving differently....
Post #567386 Sun Oct 21 2018 4:21pm
Black Bess
If this happens after a cold start it may be that you have one or two failed glow plugs. Once the engine gets going, those cylinders chime in and the problem goes away, but it can only get worse until the plugs are replaced.
Otherwise try running some injector cleaner through with the fuel. It sometimes cleans them up a bit.
Post #568035 Thu Nov 01 2018 10:25am
MartinsTDV8
Thanks guys, does feel like an injector issue Embarassed
As its a V8, I will assume it’s a pig of a job to do it. Previously owned 1999 Disco 2 TD5
Post #568375 Tue Nov 06 2018 10:47am
Black Bess
Never looked at a V8, so cannot say....
Post #568377 Tue Nov 06 2018 10:52am
