Home > Technical > 2010 Towing Electrics Curveball
215m3
I had a look at the PDF and did make sense, but thanks very much for clarifying it. Seems straight forward enough.
Just need to take care in prying the rear bumper sill cover off. 2010 3.0 TDV6 RRS Overfinch GTS
1987 BMW E30 M3 2.4 Turbo
1990 BMW E34 M5 3.6 Trackcar
Post #566762 Fri Oct 12 2018 11:20am
Brit Plumber
It comes off quite easily compared to other trims on the vehicle. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #566765 Fri Oct 12 2018 11:41am
215m3
Took the bumper off today to see the wiring.
I have ordered the set recommended. Wil it come with the wiring for the soft close boot? 2010 3.0 TDV6 RRS Overfinch GTS
Post #567085 Tue Oct 16 2018 12:23pm
Brit Plumber
Not sure what that wiring would be but if it’s part of the loom that attaches to that green plug and exits the vehicle via the big grommet and runs to the PDC sensors etc then yes it should. That existing loom goes in the bin or bottom draw and the new one replaces that and has the extra wiring for the trailer. 2019 5.0 SC SVA (Current)
Post #567107 Tue Oct 16 2018 5:16pm
You haven't actualy said what you have ordered, if you have ordered the correct kit from L/R then yes it should, if it's for a MY12 on probably not as it's in the link harness already fitted to the car, look at page 4 of the PDF for the MY10-11, if it's a pattern part or something of eBay then wouldn't know.
Post #567119 Tue Oct 16 2018 7:06pm
215m3
I have ordered this
VPLST0015
What a mine field 2010 3.0 TDV6 RRS Overfinch GTS
Post #567169 Wed Oct 17 2018 9:55am
Brit Plumber
That kit will come with everything you need. You’ll now have an extra 13 pin connector loom (your original purchase) which you can now sell on. 2019 5.0 SC SVA (Current)
Post #567199 Wed Oct 17 2018 5:06pm
215m3
All sorted and working.
The wiring for the 13 pin could be a tad longer. Just wish LR and Rimmer Bros had a clue what was required. 2010 3.0 TDV6 RRS Overfinch GTS
Post #568000 Wed Oct 31 2018 8:45pm
Brit Plumber
Thumbs Up 2019 5.0 SC SVA (Current)
Post #568001 Wed Oct 31 2018 8:58pm
