![]() | Home > Technical > Major problem |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Only a guess but possibly transfer box chain/clutch worn and slipping or something like that.
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
Thanks for your reply Col |
I think you probably need Disco Mikey, but as the transfer box is on the backend of the transmission it may be able to be removed without removing the whole transmission but as I say the possible cause of the problem was only a suggestion, sorry that I can't really be of any more help.
Cheers col
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
Without seeing the car, It sounds like a diff has collapsed, or the gearbox/transfer box splines have worn away |
Thanks Disco_Mikey |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
I'm going to be optimistic and suggest a CV joint. Many years ago a CV joint went on my Discovery 300tdi and I seem to recall loss of drive until I selected the diff lock. Probably a lot cheaper than the alternatives. Good luck. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9030 ![]() ![]() ![]() |
I'd guess the splines on one of the output flanges from the transfer box have failed. Putting it in rock crawl will lock the centre diff hence the ability to regain some drive. As the noise is said to have been present before trying to move, that would suggest the CV is not the culprit - hopefully I'm wrong as that would be a cheap fix.
Here's a picture of the transfer box and a guide on prices on some of the bits:
Oldandconfused / RRSTDV8
That would also cause the same loss of drive, though I have personally never seen a D3/Sport CV joint fail completely. Fingers crossed ![]() |
Cheers Disco_Mikey |
UPDATE.....
Drive shaft has collapsed? Presumably they mean the CV joint. Not sure what they mean by the bearing shearing. Presumably they mean the stub axle.
