Home > Maintenance & Modifications > Is this easy to yank off? (Head out of gutter please)
Andyjay123
As you can see from the photo the clips are coming loose and I’m always banging it back on
 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562359 Tue Jul 31 2018 12:04pm
It just pulls off, probably just need new clips, only a few pence each of fleabay DYC101420
Post #562360 Tue Jul 31 2018 12:10pm
Andyjay123
My main man! Thanks Very Happy Thumbs Up 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562362 Tue Jul 31 2018 12:21pm
Andyjay123
£2.40 for 10! happy days 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562363 Tue Jul 31 2018 12:23pm
Andyjay123
I’ve tried new clips but it’s srill coming away
Any other tips? I was thinking about a mastic ??
Andy 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562495 Thu Aug 02 2018 2:33pm
I found on my old TDV8 that once the trim has been pinged off - probably causing a slight twist somewhere in the moulding - those clips don't work very well. Use the solid clips such as DYC500110.
The problem with the yellow and white clips is that they come apart - this is intentional, obviously - but once there is any twist or damage in the external moulding, they clips aren't strong enough. The solid ones are better as they are, well, solid.
I used the solid ones after having tried the yellow and white ones (having resorted to duct tape to hold the mouldings on!) and the mouldings stayed on.
Don't use mastic - if they still come off you'll have a hell of a job cleaning it all up before refitting. 2012 SDV6 - it's missing a couple of cylinders
Post #562496 Thu Aug 02 2018 2:53pm
Andyjay123
Amazing , hanks so much.
I’ve ordered them via eBay. The yellow ones are a pig to get out. Used a screw driver and her to break them up 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562498 Thu Aug 02 2018 3:24pm
Andyjay123
They worked a treat! Amazing. Thanks so much 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #562562 Fri Aug 03 2018 10:31am
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #562580 Fri Aug 03 2018 12:41pm
