Home > Maintenance & Modifications > Brembo Front Brakes Help |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
I just push brembos back normally, (although a bit of a game if you push one, one of the other 3/5 pop out ) but be interesting to hear what the others say. |
Fri Jul 27 2018 5:15pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
Thin piece of wood and a G clamp? Steve. |
Fri Jul 27 2018 5:46pm |
i_dinler Member Since: 14 Nov 2015 Location: London Posts: 21 |
Pushed back easily with a flat head screwdriver.
Fri Jul 27 2018 6:35pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
On my Brembos, I had 2 flat bladed screwdrivers to lever each pad either side of the disc otherwise you can lever one back and the other moves out.
Fri Jul 27 2018 7:03pm |
I always push the pistons back in while they are in situ using a strong screw driver,as scrumps says,easier with bleed nipple slackened,I put a piece of rubber pipe on the nipple into a bottle,DONT get any brake fluid on the paint work as it will strip it in no time.
Fri Jul 27 2018 7:17pm |
Thanks for the input guys. Appreciated. Unfortunately I managed to break my locking wheel nut key so have to wait until that is sorted before doing the front pads. |
Fri Jul 27 2018 8:18pm |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
You should always unscrew the Brake Fluid Resevoir Cap before working on the brakes. The pressure has to go somewhere when you push the caliper piston back. Last edited by CANROVER on Mon Jul 30 2018 8:05pm. Edited 1 time in total |
Mon Jul 30 2018 6:54pm |
The caps aren't air tight as the system wouldn't work very well.
Mon Jul 30 2018 7:08pm |
Thanks for the advice guys.
Wed Aug 01 2018 10:21pm |
To be honest, Iād never touch the bleed nipples unless I was bleeding the system. Now you have air, all you need to do is the fronts. If you have 2 people it makes it easier but a kit will work fine. Is this the first time you have bled brakes? 2019 5.0 SC SVA (Current)
Thu Aug 02 2018 12:01am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
For whatever reason L/R do say to loosen bleed screw to retract caliper pistons on Brembos at least on the RRS1, however there is no mention of having to do it on the RRS2.
Thu Aug 02 2018 12:20am |
I definetly regret touching the bleed nipples. I used a kit called Eezibleed which works well. But it was a hard job jacking and removing all 4 wheels (22ā are to heavy). I started with the rear calipers and moved on to the fronts. Took me about 3 hrs. Yes it was my 1st time. At least its done. Thanks guys. MY14 RRS Autobiography Dynamic - Loire Blue - 2 Tone Leathers - Rear Screens - Deployable Steps - Soft Close Doors - Dual View - 360 Surround Cameras |
Thu Aug 02 2018 1:12pm |
Strange that! I changed the pads on my Brembos but didn't touch the bleed nipples.
Thu Aug 02 2018 1:36pm |
I guess so much fluid is stored in the caliper, that it would over flow the tank, and hence they say loosen nipples. |
Thu Aug 02 2018 4:26pm |
