Home > Maintenance & Modifications > Autobiography exhaust tips TDV8
RRSV8
Hi guys
Will be fitting AB stainless exhaust tips in next few days on my TDV8
bought from powerful uk, will they slide on or will i need to cut part of tailpipes off ?
many thanks.
Post #560601 Tue Jul 03 2018 5:43pm
As the Diesel tailpipes point down and A/B ones come out basically straight, I would think you will need to cut the downward bend off. Also will you not need the A/B rear bumper as well for them to look right or at least cut the original bumper where the exit the car ?
Post #560623 Tue Jul 03 2018 10:25pm
RRSV8
Thanks pal, Will be fitting AB bumper as well.
Post #560627 Tue Jul 03 2018 11:12pm
Brit Plumber
The AB style diesel tips bend down too, the open square end is fake. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #560630 Wed Jul 04 2018 12:30am
Yes, but the outlet from the A/B rear silencer is straight and as you say the bend is in the tailpipe finisher, as they never produced a pre-facelift A/B Sport they were only introduced from MY10 on, then the bend is in the rear silencer outlet pipe on the diesel pre-facelift.
Post #560634 Wed Jul 04 2018 1:05am
Brit Plumber
I see what your saying now, cut the bend off the back box and replace with the new AB style bent tips. 👍 2019 5.0 SC SVA (Current)
Post #560635 Wed Jul 04 2018 1:34am
Yeah, sorry should of made it clear that I was referring to rear silencer outlet not the actual finisher tip.
Post #560637 Wed Jul 04 2018 1:45am
