Home > Technical > Nasty Knock / Clunk
Robbo88
United Kingdom 2008 Range Rover Sport TDV6 HSE Santorini Black
Nasty Knock / Clunk
Hi to you all , when reversing into my driveway on full left lock there is a horrid clunk that comes from the lower front end. Can anyone please tell me what this might be ? Thank you very much. Sad 2008 RANGE ROVER SPORT
Post #558355 Thu Jun 07 2018 12:27am
wilchesth
United Kingdom 2008 Range Rover Sport TDV6 SE Zermatt Silver
I got the same problem and it is getting louder recently but it doesn't do it all the time. I checked my old MOT advisories and shows this:
Nearside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement wishbone (2.4.G.2)
Offside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement wishbone (2.4.G.2)
I wonder if it is about to pop soon.
I'm booked at the garage on Tuesday, I will let know what it was. Mine is also 2008. 2008 Range Rover Sport 2.7 SE Zermatt Silver.
Post #558386 Thu Jun 07 2018 12:15pm
Robbo88
Thank you for your reply . Yes, please let me know . It will be appreciated. Thank you take care . Rob
Post #558407 Thu Jun 07 2018 6:38pm
wilchesth
Well I took the car to the garage yesterday and they couldn't pin point to the source of noise. They said nothing looked broken but there were a few suspects (front diff, cv boots) but they weren't willing to replace them as they weren't 100% sure. They told me to come back once the noise got worse. It wasn't a Land Rover garage so I might take it to the local indi next time. 2008 Range Rover Sport 2.7 SE Zermatt Silver.
Post #558859 Wed Jun 13 2018 9:26am
wilchesth
UPDATE: I took it to Land Rover garage for a health check and they found a front wheel bearing a bit wobbly and a problem with the propshaft center bearing which was split. So I wonder if the clunk is caused by the front wheel bearing. Saying that I haven't heard the noise for over 2 weeks. 2008 Range Rover Sport 2.7 SE Zermatt Silver.
Post #560452 Mon Jul 02 2018 2:50pm
Robbo88
Hi, update on my clonking from front end ... it was the lower arms . Had them replaced with 4 wheel align at £500 all in 😥. All lovely now .
Post #560895 Fri Jul 06 2018 10:32pm
