![]() | Home > Technical > How do you rate your air con? |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 ![]() ![]() ![]() |
Hi guys,
Hi guess
Better than the air-con in my renault |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
turn it down to 19 or 19.5°
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
20? Well it won`t feel cold set to 20.....I`ve always turned my temp (on all cars) to coolest setting, usually 16 and then the AC is lovely and cold. Steve. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9030 ![]() ![]() ![]() |
I usually set mine to 20 for normal weather. If it's warm then 16 or LO until it's cooled down a bit then back to 20. Means the fan's not running noisily all the time. 2012 SDV6 - it's missing a couple of cylinders
only yeah I have used them tricks previously. |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
I set to 20°, a/c on and 'auto' all year. When it needs cool air, it blows cold air and it is chilly.
