Home > Maintenance & Modifications > Hand brake shoes
doyleywood
Hand brake shoes
First post please be gentle, 06, RRS SC, 86k miles, developed a scraping noise from NSR disk while moving , hand brake working fine when parked up, local garage thinks hand brake shoes lose and have moved and are scraping against disk/back plate, brakes are working fine, plenty left on pads and disk, no excessive heat , the garage cant fit me in for a few weeks, so thinking of doing it myself, just wanted know if any one else done there own, can you do a DIY job or has the car got to be plugged in to a computer to reset the hand brake, any think you cant do at home . thanks in advance. steve
Post #550775 Thu Mar 08 2018 12:18pm
It can be done DIY.
recommended to remove the large handbrake fuse to stop tiny fingers pulling on the brake .
Main thing is to ensure the arm on the rear of the shoes is moving and greased.
see bodsy bible
http://www.rrsport.co.uk/forum/topic28424.html
Post #550778 Thu Mar 08 2018 12:39pm
Black Bess
Yes, nothing unconventional about it. You can do it yourself if you are familiar with these things.
They do tend to get a lot of rust and scale in there, so a good clean out may be all that is needed.
Post #550783 Thu Mar 08 2018 1:48pm
doyleywood
thanks for the advise
Post #550930 Sat Mar 10 2018 4:30pm
