![]() | Home > Maintenance & Modifications > 2009 V8 HSE - banging noise |
Viper61 Member Since: 14 Feb 2018 Location: Hertfordshire Posts: 5 ![]() ![]() ![]() |
Hello all, been lurking for a while and found some great help / tips on here.
Could’ve anything from a CV joint to a loose wheel only way is jack up the car and investigate, good luck 2008 G4 RRSport TDV8 current
*UPDATE*
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
I had the same noise problem on my RRS 3.0 MY60 Sort of clatter on going around mini roundabout.. It turned out to be ARB Bushes. Had them changed for poly bushes Problem gone itisme |
