![]() | Home > Maintenance & Modifications > Drls |
Morgi27 Member Since: 31 Jan 2015 Location: Birmingham Posts: 88 ![]() ![]() ![]() |
I've found this on ebay think they been suggested used before on here eBay Item No. 142018758904 ebay number
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
Those DRL units will use a voltage sensing relay to turn on the lamps, so the only connections will be to the +ve and -ve terminals of the battery.
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 ![]() ![]() |
Easy fix, wire them to an ignition live terminal in the under bonnet fuse box |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
Its easier than you think to fit halos, opening headlights isn't too bad.
