Home > In Car Electronics > Idiot Proof Install. |
I’m also after this info Peachy,,I’m sure someone posted somewhere on here which fuses to connect to.At the minute I’m using the cig lighter to power mine but I’m wanting to hardwire it.
Sat Dec 02 2017 4:17pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Andy - thanks for the quick reply - is your front cam to the drivers side of the rear mirror - I read it was a pain to remove - access it in that position but I don't seem to have that issue 16MY Estoril Blue SVR.............
Sat Dec 02 2017 4:30pm |
Yes mine is to the drivers side of the mirror,,makes it easier if I want to press the button to record.
Sat Dec 02 2017 4:59pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4972 |
Peachy, Although a RRS1 I can't see RRS2 will be much different, I experimented with trying camera either side of mirror and found if fitted on passengers side with the camera lens being on the end of the unit and curvature of the screen, it put the lens way off centre of the vehicle, and although not a lot of use it made it virtually impossible to align the Lane Departure feature of the camera. In addition the power and rear camera leads are the lens end of the unit and it didn't really make a tidy install to me. Although not the perfect position it is certainly more easily accessible and better fitted behind the mirror on the drivers side. Cheers Col |
Sat Dec 02 2017 7:47pm |
Cheers Col - I've been out & trialed its location - the right side of the rear view mirror is where it will be placed it's a bit cold & dark to start messing around now but will have another play in the morning - hope your enjoying your new surroundings
Sat Dec 02 2017 8:35pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
I might be being a bit thick here, but how does the lane-departure feature know that you haven't deliberately changed lane? Does the warning go off quite a lot? |
Sun Dec 03 2017 10:11am |
It's a bit basic really, simply picks up white line markings so every time you change lanes it just beeps at you a lot, which is why I have mine disabled. I think the general idea is to let you know if you start to wander across the white line a bit.
Sun Dec 03 2017 10:50am |
Thanks. I think I'd quickly tire of that. |
Sun Dec 03 2017 4:18pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
Much easier and less hassle to use an auto electrician imo Steve. |
Sun Dec 03 2017 4:32pm |
