Home > Technical > Remap Options
Page 2 of 3 <123>
Paddi
Good rant Laughing but I don't thinks anyone was really having a go at you.
To get back on topic I don't think you can have a switch to go from one map to another since changing maps involves overwriting the ECU firmware and that can't be done instantly. Some exotic cars do have switchable modes but I'm guessing that involves a whole lot more electronics hardware.
With those rubbish so-called 'tuning' boxes (that are really just a fancy box with a resistor inside to fool the ECU into overfuelling the engine) it is possible to have a switch but that's different and not what you are looking for. 2008 MY Java Black TDV8 HSE
Post #514952 Wed Jan 18 2017 5:24pm
I'm sure the old M5's use the sport or Race button.
For example, normal mode, 300bhp, sport mode 500bhp.
The button adjust all sorts of things, throttle response, gear shift, power, suspension, traction control cut in etc.
The old astra 200bhp FWD also has a sport button on the dash, I assume this limits the power. Very useful for a powerful FWD.
Even the 150bhp diesel had a button.
Post #514958 Wed Jan 18 2017 5:39pm
Disco_Mikey
But the buttons were all integrated from the start by the factory Thumbs Up
Post #514983 Wed Jan 18 2017 8:01pm
Socast
TBH while I had my fingers crossed in hope, I kind of already knew that the answer was going to be no Big Cry
Post #515028 Thu Jan 19 2017 8:08am
Disco_Mikey
Either way, you won't be disappointed Thumbs Up
Post #515029 Thu Jan 19 2017 8:10am
Socast
I've changed the exhaust, I'm debating whether to have the top pulley and a remap done at the same time..
Post #515032 Thu Jan 19 2017 8:19am
SRE
Spain
Socast
It may be beneficial to post some info about your car, year miles etc etc.
Also talk to BAS and Alive. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #515197 Fri Jan 20 2017 2:55pm
TheWojtek
This is beneficial. There's no way to make a switchable map, however if driven lightly you will see a small improvement in MPG, since you'll be running a tad leaner and the ignition adjustment will allow the mixture to burn better. Any wider throttle opening, however, you'll be using bucketloads of fuel. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #515206 Fri Jan 20 2017 4:46pm
Buckster
My SDV6 is Alive! Pulls like a train now and the torque is superb. Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #515216 Fri Jan 20 2017 6:24pm
Ezituper
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
Isn't saying "or thought about doing any of those tacky 'mods" just as snide as the remarks you were complaining about?
I'm also trying find someone to fit a smaller pulley and remap, I am however concerned my most local options don't have a rolling road so are just flashing generic tunes.
As we proved on the SRT8 forum this can be dangerous at worst but at best only part way to a proper tune.
After testing 10 "identical" cars before and after tuning they all differed to some extent, the best and worst differed by over 40hp.
When they were given individual tunes not generic ones they all released more HP and the differential reduced to only 12 HP from worst to best.
Most generic tunes are "safe" as the original tuner has little or no idea what else you might have done to your car
Can any one help with a company who install smaller pulleys, tune and rolling Rioja do test the results ?
Post #515219 Fri Jan 20 2017 6:46pm
Socast
My remark about the 'mods' could be considered to be snide, but it wasn't directed at anyone and it was also an opinion rather than an insult.
http://www.powerhouse.uk/index.php
Pretty much the only people in the UK that specialise in machining the nose cone down etc.
Changing the pulley will give you an increased boost at low revs, giving you more power at launch, however the supercharger starts to loose power once it hits 15,500rpm so by putting a smaller pulley on you're moving the power lower down the rpm range and decreasing the life of the charger. Not only that but at higher rpms the eaton charger develops an inordinate ammount of heat, so unless you improve the intercoolers you're not really going to see any benefits (other than a frantic 40 second dash followed by an asthmatic limp while everything cools down).
The best/safest mods for this engine (when on a relative budget) is to replace the exhaust with a stainless high flow system and removing the cats at the same time, improved intercoolers and aux pump all rounded off nicely with a remap (from what I've seen Alive are one of the most trustworthy).
Post #515567 Mon Jan 23 2017 3:42pm
Tyrefitter
15,500rpm Shocked Shocked
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #515568 Mon Jan 23 2017 3:52pm
Socast
Thats the supercharger speed, not the engine speed, I've had a look round and can't find the ratio that the charger spins at comparatively to the engine.
This website gives ratios for the Eaton M112 based on upper and lower pulley sizes. But as I'm at work and don't know how big the stock pulleys are I'm unable to say when you'll hit th 15.5k boost limit.
http://planetsoarer.com/boost/boost.htm
Post #515569 Mon Jan 23 2017 4:02pm
Ezituper
Good info but I'm confused why various sites say you can get 40-50hp from a 10% pulley but you say it goes asthmatic and does nothing
I've been on various forums long enough to ask where this info came from?
Post #515631 Tue Jan 24 2017 12:10am
Not sure about ratio's or rpm for that matter but I do know Alive Tuning re-mapped my 5.0L S/C and fitted upgraded s/c pulley and it pulls like a train all the way with no noticable "tail off". According to their rolling road it's producing 560+bhp and 750Nm torque. Twisted Evil
CheersCol
Post #515634 Tue Jan 24 2017 1:11am
Page 2 of 3 <123>
