Home > Technical > Not starting after engine rebuild. Lots of messages.
Charlieboyy
2008 Range Rover Sport TDV6 HSE Chawton White
Hi guys just rebuilt the bottom end on my RRS 2.7 tdv6. Put the the body back on yesterday and today was the big start up day but she didn't start. It came up with some messages on the dash saying hdc fault and gear box fault. I plugged the dianostics in and came up with about 20 faults I'll put some pictures on with the codes. I's is a case just taking it to land rover and getting the ecu''s reset or is there a way to do it your self iv done loads of reading and only found how to do a simple reset. Thanks for any info guys. Charlie
Post #513901 Sun Jan 08 2017 10:12pm
Did you touch the crank sensor ???
Post #513907 Sun Jan 08 2017 10:55pm
Charlieboyy
Yes I removed it when I took the crank out and put it back in when rebuilt it.
Oh no what have I done!!!!!
Post #513910 Sun Jan 08 2017 11:47pm
Do a search on here.
I think you need a special (and very expensive) tool to re align it.
And as usual the manual recommends changing the wheel with the magnets in.
Could be something else of course.
Post #513926 Mon Jan 09 2017 12:04pm
Charlieboyy
OK thanks Andy would it be the trigger wheel alignment tool or the crankshaft sensor alighnment tool, I can only find a tool that aligns the trigger wheel ( the wheel with the magnets in). Looks like I'll be taking the body off again tonight. Thanks for your help mate.
Post #513938 Mon Jan 09 2017 1:39pm
yeah trigger wheel.
Haven't done it myself, just read about it on here.
You may want to see if an injector fires. If it does, the crank sensor could be ok
Post #513965 Mon Jan 09 2017 6:23pm
