Home > General (L494) > Fuel tank seems smaller than 86 litres it should be ? 306 BH |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
Range Rover and others give a lower to empty reading than actual. At 2 miles to go you may still have 5-8 ltrs left.
Thu Jan 05 2017 3:07am |
alexa111s Member Since: 27 Jun 2016 Location: Sevenoaks Posts: 62 |
Thanks CRACKA
Thu Jan 05 2017 9:04am |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
The most I have ever got into my tank is 79.6 litres, I don't recall that being at anything much under 20 miles range left, and so I would not really doubt the advertised capacity.
Thu Jan 05 2017 9:25am |
Triple7 Member Since: 27 Oct 2011 Location: Wiltshire Posts: 154 |
Does the adblue tank take up fuel tank capacity like in the DS? Gone:
Fri Jan 06 2017 5:10am |
I don't think so, the filler being in the engine compartment? Makes me assume the adblue tank is thereabouts too. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Fri Jan 06 2017 8:00am |
Good pint! Gone:
Fri Jan 06 2017 9:03am |
Well I'm convinced its not the size advertised.
Fri Jan 06 2017 9:49am |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
The fuel tank is shown in the spec. as 89 'usable' litres with both V6 and V8 engines, and that's in current models with AdBlu tanks. |
Fri Jan 06 2017 11:43am |
Lobster Member Since: 22 Feb 2009 Location: Adelaide, Australia Posts: 16 |
My Australian Spec 2016 RRS SDV8 HSE Dynamic has "Fuel tank capacity - usable 105 litres" as per my saved Land Rover Online Configuration.
Fri Jan 06 2017 1:31pm |
Do you have AdBlu in the Antipodes, though? That reduced tank capacity in the UK. |
Fri Jan 06 2017 1:46pm |
Off this topic, but how do you like your SDV8? I've just ordered one in preference to a V6 (despite being unable to get a test drive in one) and having read 'mixed' reviews to say the least. I did manage to drive an SDV8 FFRR, which I thought was great, and I'll be well pleased if the RRS with the same engine gives the same pleasure. Have you driven an SDV6 as well? How do you reckon they compare? |
Fri Jan 06 2017 1:51pm |
Donny,
Sat Jan 07 2017 3:44am |
Unfortunately, I couldn't get a test drive in an SDV8 (they are as rare as hen's teeth in the UK so it seems) so had to make do with an SDV8 FFRR. However, if the RRS SDV8 performs anything like as good as the FFRR I'll be well pleased. I was also impressed with the engine note from outside, which, although not burbly, was certainly not diesel-like. (Inside the FFRR you couldn't hear the engine at all, but the car I tested had double-glazing).
Sat Jan 07 2017 9:05am |
I have found that the latest software upgrade which was not labelled as a performance upgrade (Q634) seems to have remapped something in either the engine ECU or the gearbox ECU and I find that the tiny bit of hesitation that there was is a thing of the past, the car is now very responsive to the throttle at all revs. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Jan 07 2017 9:51am |
