Home > Technical > Can active cornering lights be turned off via diagnostics
highfellzippy
Can this be switched off via. Obd
If so what setting is it located in please Smile
I'm doing a 2010 facelift. And new lights don't have. Active cornering
Post #512771 Thu Dec 22 2016 7:57am
Tim in Scotland
I thought Active Cornering was ACE - part of the suspension system - do you mean ADAPTIVE headlights with cornering spotlights that come on below 30mph to illuminate corners / kerbs? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #512775 Thu Dec 22 2016 8:19am
highfellzippy
Yes AFS
CORNERING LIGHT
Post #512830 Thu Dec 22 2016 7:27pm
Disco_Mikey
The adaptive part can be disabled, while retaining the corner lights, or the whole lot can be disabled Thumbs Up
Post #512831 Thu Dec 22 2016 7:51pm
Johnski
Or don't use indicators also stops them coming on. Mr. Green John
Post #512834 Thu Dec 22 2016 8:17pm
Eaters
My cornering lights come on at low speed whether or not I use the indicators Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #512846 Thu Dec 22 2016 11:32pm
Johnski
Mine come on under 30mph with indicators on, but I've not actually notice if they do it automatically. Embarassed John
Post #512882 Sat Dec 24 2016 3:02am
HemoRRS
My 2009 used to come on without indicators, but my 2010 only comes on with indicators..
Post #512884 Sat Dec 24 2016 8:13am
Tim in Scotland
IIRC they should do both, with indicator on or at less than 30mph if the steering wheel is turned by a certain amount - when I had them on my Evoques and the TDV8 RRS they came on at night when I was negotiating twisty local country back roads at less than 30mph and also going up and down the access ramps in multi-storey car parks. Passengers sometimes used to remark about the "little light" that came on when I was negotiating turns. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #512887 Sat Dec 24 2016 8:52am
gogsy1956
Mine come on all the time,, didn't realise they only worked at less than 30 mph but sensible when you hint about it! 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #512929 Sat Dec 24 2016 8:34pm
hafman
#numpty_question: My pre-owned L494 (MY15) Autobiography Dynamic doesn't seem to have what I assume are called Active Cornering Lights; what should I look for on the dash to confirm this?
TIA
Post #512930 Sat Dec 24 2016 9:25pm
Tim in Scotland
There are some cars that have to have a recall applied to make them work - some late 2015MY and early 2016MY Autobiographies IIRC. They don't need any enabling in the dash menus. Best way to find out is at night to turn on the headlights, turn the steering wheel to full lock and see if you can see the small spotlight in the headlamp unit come on, it can be seen from the driver's seat 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #512933 Sat Dec 24 2016 10:13pm
shakeapaw
mine come on without the use of the indicators, but only on sharp bends 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #513343 Mon Jan 02 2017 12:51pm
