Home > Technical > Auto Low Beam |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
When this technology first came in, it used to be in the rear view mirror. (forward facing)
Thu Sep 08 2016 11:16am |
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 |
OK so where is the rain sensor? RRS (MY13) Santorini Black SDV6 HSE luxuary
Thu Sep 08 2016 11:25am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
I think it's in the middle of the screen where the rear view mirror attaches. You should see small solar type box from the outside. Not sure how you'd blank it to be honest. ON THE WAY: BMW F21 M140i
Thu Sep 08 2016 11:31am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
I thought the rain sensor was the black hatch area at the top of the screen in front of the rear view mirror? 2010 RRS, TDV8
No, it's usually just below the mirror mount. |
Thu Sep 08 2016 11:50am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
Not the best picture but,
Thu Sep 08 2016 12:13pm |
Hi Col
Thu Sep 08 2016 2:21pm |
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 |
Rain and light level sensing is done by the same unit so I don't think blanking would work, but you could verify that by covering the rain sensor with a paper (while wiper is set to off) to see if the lights would turn on.
Thu Sep 08 2016 3:08pm |
I wasn't sure what the one below the rain sensor, but as udash picture shows it is a image sensor although I have it on mine I have no idea what image it is supposed to sense. According to the W/Shop manual it is all part of the High Beam Assist by detecting the proceeding vehicle Tailights etc. if I understood it correctly.
Thu Sep 08 2016 3:20pm |
Hi undash & Col
Thu Sep 08 2016 3:44pm |
Throw water on the screen, that will test it
Thu Sep 08 2016 4:22pm |
Why not just use the dipped beam light position on switch instead of Auto? Then the dipped beam will remain on unless you use main beam which isn't likely much in daylight, but remains under your control.
Thu Sep 08 2016 4:44pm |
Why not just activate the "Scandinavian" setting in the CCF Files and dipped beam will come on irrespective of the position you have the Headlight Switch in as soon as you Start the Engine.
Thu Sep 08 2016 5:13pm |
Col, I think image sensor is also the camera that's used for traffic sign recognition apart from AHBA. A loan Evoque I had recently had two such cameras separated by around 6cm and that was used for Collision detection, cheaper and less reliable way of doing it rather then with the RADAR that we have got on ours. |
Thu Sep 08 2016 6:29pm |
