Home > Technical > New Brakes all round
dpg123
Col wrote:
Hi'
Apologise, you are probably right not having a good day really, Sad it is easier if you have a second pair of hands to help support the spoiler though, as easy to mark/scratch the paint on the roof with the three longish mounting studs if trying to juggle it on your own.
Col, I apologise! You are right - the MY10 rear light/spoiler is different. It's got the reverse camera etc as well and the assembly is different. Have you any tips on removal?
Post #502641 Fri Aug 12 2016 7:31am
To be fair the spoiler removal procedure is about the same, If I remember correctly the light unit is held in with a couple of 4/5mm nuts' not screws, the camera is just second electrical plug to disconnect. As I said I would suggest a second pair of hands to help as the washer pipe and plugs can be a little awkward to disconnect if tight while balancing spoiler at same time. Preferential to marking or scratching the roof paintwork.
Post #502643 Fri Aug 12 2016 8:01am
Pufftmw
Er Col?
Why are you talking spoilers and brake lights in a discs n pads thread? Whistle
Post #502648 Fri Aug 12 2016 9:00am
Sorry did get side tracked a little bit but if you read full post it did digress to rear spoiler at one point.
Post #502651 Fri Aug 12 2016 9:38am
gavwhite1972
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
DrRob wrote:
Buy Genuine and buy them from Dan at Duckworths (forum sponsor - search on here and tell him you are a forum member). Significantly cheaper than a main dealer
Rob... can you tell me how to find Dan... the sponsors page seems very out of date and i can't see anyone called Dan...
I need prices for new discs and pads all round...
Gavin
Post #504151 Tue Aug 30 2016 10:35pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Go To Site Sponsors
Duckworth Parts and just write an email enquiry to Dan in there
Post #504153 Tue Aug 30 2016 11:02pm
SRE
Spain
Why not use one of the Guys on this and /or the Disco 3 forum to do the job. Do a search on here for Geoff he is Kent based.
http://www.disco4.com/forum/sponsors.php
Plus there is the brake Guru Bodsy, (Shropshire) Do a search for Bodsy's Brake Bible In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #504161 Wed Aug 31 2016 7:07am
SRE
Spain
Here you go, Disco 3 same as your car.
http://media.disco3.co.uk/gallery/albums/u...1.4sml.pdf
Use the search on these forums, loads of info, just for starters:-
http://www.rrsport.co.uk/forum/topic28424.html In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #504164 Wed Aug 31 2016 7:14am
gavwhite1972
Re: Go To Site Sponsors
Sorted, thank you....
Post #504253 Wed Aug 31 2016 10:29pm
gavwhite1972
I'm in north Notts.... will have a search once I get prices for the parts and compare to the supply/fit price from Marshall LR in Lincoln...
Post #504254 Wed Aug 31 2016 10:30pm
Gerd1986
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
I recently replaced all disks, pads and sensors on by 2012 sdv6 with Bodsys brake bible incluing buying all the tools needed for under £500. Very simple to do yourself.
Brembo:
Pads rear 33.99
Pads front 63.99
Disks front 151.98
Disks rear 97.98
Sensors 12. 00
Plus euro car parts always have a sale on, i got an email today with 30% off same as the discount i got on the above prices a few weeks ago.
Plus I now own a whole heap of tools, including a 3ton trolly jack, axle stands, torque wrenches the list goes on.
Im in essex if you want a hand or need to borrow some tools.
Post #504255 Wed Aug 31 2016 10:50pm
SRE
Spain
have a look here:- http://www.disco4.com/forum/sponsors.php
Some guys are mobie, Flack & Wiggs are North West based, not that far from you. Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #504263 Thu Sep 01 2016 6:07am
