![]() | Home > Maintenance & Modifications > Another "clunking" thread! |
Deefur Member Since: 09 Dec 2015 Location: Dunfermline Posts: 19 ![]() ![]() ![]() |
Strange one this, hopefully you guys can help me out. I'm getting a clunk whenever I'm cornering. Low speed cornering is fine even at full lock. It seems to be a weight transference issue, whenever the weight moves from one side to the other - clunk! going over bumps is fine, no clunk so I think the suspension is fine.
I should add the noise isn't from one side it seems to be coming from which ever side the weight moves from, left or right, front or rear!! |
Worn loose or broken droplinks?
The drop links were the first thing I had checked but the garage said they're absolutely fine!! |
