Home > Maintenance & Modifications > Brembo Brake Upgrade |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4973 |
There is a procedure in the Workshop Manual but basically start Furthest from Master Cylinder N/S/R, O/S/R, N/S/F, O/S/F.
Wed Jun 15 2016 8:31am |
tonywolf Member Since: 14 Sep 2015 Location: Devon Posts: 97 |
Thanks Col, rear callipers to be bled even though I'm not touching the rears? As you are aware there are 2x bleed nipples on the Brembo callipers, can I presume I only need to bleed from one of them per calliper i.e. the outers? Best Regards
Wed Jun 15 2016 8:55am |
Hi Tony,
Wed Jun 15 2016 9:46am |
My friend you are a font of knowledge, many thanks Best Regards
Wed Jun 15 2016 9:58am |
