Home > Technical > Fault Code P117E
Mhenderson2
Scotland 2007 Range Rover Sport TDV8 S Java Black
Fault Code P117E
Diagnostic tool showing P117E - Fuel volume regulator control exceeded minimum control limit. Changed fuel filter but car still goes into limp mode shortly after starting and travelling short distance. Stop and restart car and it's OK for the rest of the day! Has any one had this fault and if so would be grateful for advice?
Post #498029 Mon Jun 06 2016 7:58pm
shakeapaw
I believe its the high pressure fuel pump that is faulty, not the one in the tank, the one that sits in the engine bay and pumps fuel under high pressure into the common rail 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #498351 Thu Jun 09 2016 10:15pm
Bobby
P117E-00 Fuel Volume Regulator Control Exceeded Minimum Control Limit
Faults:
Fuel volume control valve circuit fault
Fuel volume control valve fault
What to do:
Check the fuel volume control valve and circuits. Refer to the electrical circuit diagrams.
Check the resistance of the valve and install a new high pressure fuel pump if the resistance is not between 1.5 and 15 ohms (the fuel volume control valve cannot be serviced separately).
Clear the DTCs and test for normal operation Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #498372 Fri Jun 10 2016 11:30am
Mhenderson2
Thanks for the replies! Could the common rail pressure switch cause this? I'm not that technical but work mate thought it might be worth trying first.
Post #498397 Fri Jun 10 2016 6:47pm
