Home > General > Lumpy at tick over |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
if it feels like a shudder/wind blowing past then its the air suspension, almost certainly a dicky sensor or a leak ============
Thu Sep 22 2011 9:34pm |
Storn Member Since: 27 Jan 2011 Location: IOW Posts: 22 |
After doing a search on here for 'juddering' and 'lumpy' this is as close to what I can find, so a ressurected thread at least...
Mon Jul 23 2012 4:30pm |
ross24061986 Member Since: 28 May 2016 Location: United Kingdom Posts: 9 |
I have a 2010 rr sport done 157000, full genuine Land Rover servicing by myself as I work for main dealer.
Sat May 28 2016 9:02pm |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
Ross yours sounds like an injector. |
Sat May 28 2016 11:17pm |
injectors all seems to be the same readings nothing that stands out? cheers |
Sun May 29 2016 11:40am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Ross, have you got a weak hydraulic tappet weeping off, then taking a few seconds to build up pressure on start up ? Also has hemp above has said injector, not all faults show up electronically could be mechanical spray pattern etc. Have you checked compressions ? 2008 G4 RRSport TDV8 current
Sun May 29 2016 4:51pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
Mine used to have a lumpy tickover on occasion, then it eventually developed into a restricted performance fault. After a restart it would run but you could tell it wasn't right. Totally gave up after it had been standing for a couple of days,, clouds of blue / white smoke from left exhaust, turned out to be a egr valve.
Sun May 29 2016 5:03pm |
Was going to surgest warped manifold on o/s has it pulled the studs out ? 2008 G4 RRSport TDV8 current
Sun May 29 2016 5:11pm |
Surely I would see smoke with warped ex manifold or studs loose?? The worst is outside work on such a very slight incline makes it worse from cold start up every time I leave to come home. Data logger on injectors from cold I think next. |
Mon Jun 06 2016 6:51pm |
