Home > Technical > Strange suspension problem
Flatteraxe
United Kingdom 2007 Range Rover Sport TDV8 HST Java Black
Hello all,
Had the following fitted today at a garage I know on my 07 TDV8:
Front lower wishbones
Track rod ends
Anti roll bar bushes
Front stabiliser drop links
As the car drove out of the garage it stayed at access height and would rise. I told them this wasn't normal and they claimed that it had registered a suspension fault when they first started it up after I had dropped it off (highly doubtful).
I got them to fault code read it and it had registered a fault but they wiped it before I could note it down. Car re-started and it rose fine and I thought all was well. 2 miles away from the garage the fault popped up again and it said 'normal height only'. I pulled over and restarted the car and the fault cleared, I raised the suspension but when I tried to lower it I realised that the button to lower it doesn't work. There is no resistance or click to the button, its like there is simply nothing below the button, it just flaps about. I had to get the car to over 30MPH for it to lower itself. It drove fine again but again after a couple of miles the fault popped up again.
The car doesn't seem to drive any differently with the fault. I would suspect the pump but it had a new one less than a year ago plus when it raises it does it fine without any undue noise.
Could the button be at fault and can I replace just this part? It isn't sticking or anything as the car would constantly try to lower and it doesn't its like someone has removed whatever is supposed to be behind it.
Sorry it's long and thanks for any help.
Post #496358 Tue May 17 2016 8:30pm
Socast
I don't think it's a fault as such, more likely damage to the switch. You may be able to get away with a simple repair or it may require the panel to be replaced, without actually removing the part you won't know for sure.
Here is a link to an 05 to 09 RRS terrain response panel:
http://www.ebay.co.uk/itm/Range-Rover-Spor...SwfZ1WZ~X-
Either way I would suggest checking the button for impact damage.
Out of curiosity was the garage you took the car to a Landrover dealership, specialist or was it a generic garage ?
Post #496395 Wed May 18 2016 8:04am
Johnski
All parts fitted in LR dealerships, service centres are guaranteed for a minimum of one year, some two years,
so well worth returning to the garage if you think it is the pump.
If you have access to a code reader such as the IID BT tool this can also adjust suspension heights etc,
But from your description it sounds as if you definately have a faulty switch that requires replacing, I wouldn't have thought that would cause the fault you describe, but until rectified you won't know. I would return car to garage as you don't expect to have a faulty car at pick up?
Sorry had started writing reply and had to pop out, now I see the above post has said much the same. Embarassed
Would have deleted but you can't. Sad John
Post #496398 Wed May 18 2016 8:41am
Flatteraxe
Thanks for the input guys. There doesn't seem to be any impact damage on the button, it may have been broken for a while and I haven't noticed as I hardly ever use it. It just seems funny that the car went to the garage and now it has a fault. The garage is an independent, I sort of know the guy. Thing is, on the parts he has changed for me, he wouldn't have been anywhere near the suspension would he? I'm just wondering if he's accidentally forgotten to re-attach something or similar along those lines.
Can I swap that control panel out myself or is it a job for a specialist?
Thanks again.
Post #496426 Wed May 18 2016 3:32pm
Camelrock
Everything barring the TRE is suspension. You need the fault code reading and recording then go from there ...
Try putting the 4x4 info screen up does it show one of the hight sensors out of range ? 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #496430 Wed May 18 2016 3:49pm
Flatteraxe
I just had the tracking done and the guy cleared the fault code before I could note it down but he said it was:
Invalid signal from air suspension control module
The 4x4 info screen doesn't show any faults. As expected, about a mile from the tracking place the fault popped up again. I have ordered that terrain response panel, is this an easy fit or is it a job for the garage?
Post #496616 Fri May 20 2016 3:01pm
The air suspension control module is not in the terrain response panel (that's the air suspension control switch).
The module lives on the driver's a-pillar behind the dashboard. You access it through the foot well above the pedals having removed a couple of panels (easy to remove). It would be worth checking that the wires are all pushed home - if someone has tried to disconnect a plug they may have pulled on the wiring to do so. Any loose wires will throw an error. 2012 SDV6 - it's missing a couple of cylinders
Post #496634 Fri May 20 2016 6:47pm
Flatteraxe
Hello thanks for the response. The terrain response panel is because the button to lower my suspension has somehow broken.
Does anyone know if it's an easy job?
Post #496639 Fri May 20 2016 7:31pm
Socast
It's pretty easy but tbh it all depends how confident/capable you are. Everyone is different 😄
Here's a link to a video that shows you how:
Post #496643 Fri May 20 2016 7:44pm
