Home > Maintenance & Modifications > RRS MY12 Brake upgrade |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
If your looking for someone to carry out the work check out Quattro auto are they are in Riccall which is right on your doorstep. As for fitting brembo' s, I think it depends on what size wheels you've got as some of the smaller ones will not fit over the bigger calipers. I' m sure there are a few threads on this subject. 2010 RRS, TDV8
Fri Apr 29 2016 10:46am |
That should be Quattro autocare, stupid predictive text 2010 RRS, TDV8
Fri Apr 29 2016 10:48am |
sean2204 Member Since: 05 Mar 2016 Location: York Posts: 55 |
Thanks gogsy.
Sat Apr 30 2016 4:26pm |
Minimum size wheels are 19 or 20 inch, do a search on here for brembo upgrade,,, lots of info and part numbers 2010 RRS, TDV8
Sat Apr 30 2016 6:19pm |
deano_123 Member Since: 13 Aug 2015 Location: Newcastle Posts: 108 |
Discs are known to warp due to people sitting with their foot on the brake in traffic causing hot spots following braking.
Sun May 01 2016 2:54pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4400 |
A 2012 RRS already has Brembo sized discs + pads. All you would be gaining is some visual stimulation
Sun May 01 2016 3:09pm |
I'm pretty sure mine doesn't have Brembo discs and pads. It's a 2012 HSE Lux SDV6... |
Sat May 14 2016 5:09pm |
