Home > General > Potential RRS owner trying to decide... |
The dials were outdated green glowing LCD's in May 2005 at the car's launch but that was pretty hi-tech for Land Rover then and most of it came from BMW and Ford anyway as they were the owners of LR up until then! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Apr 07 2016 9:13pm |
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 |
First issue already The classic invisible obstacle when lowering to access mode. Worked during the test drive, but not after they replaced the front bushes as I noticed yesterday. Car thinks there's an obstacle by the front right wheel, flashing red light on the 4x4 display. Raises to extended nice and quick, and I have to switch back to standard height. The front right then lifts slightly when I start driving and the rest of the journey is on a slight wonk. Until it raises itself, turning right throws a bit of resistance until you get the wheel moving between 20ish - 40ish mpg. Once it's raised the right front side all is well.
Sat Apr 09 2016 12:08pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Yes, almost certainly just a calibration. I presume a full 4 wheel alignment has been carried out? Whilst you're there, make sure the Steering Angle Sensor has been recalibrated too. Visiting from DISCO3.CO.UK
Sat Apr 09 2016 12:14pm |
Yeah the 4 wheel alignment was done after the bushes were done. Perhaps they did that but not a ride height calibration? I'll mention that one to them too, thanks! Could the resistant steering be the car not wanting to turn due to thinking it's bottomed out? It seems to be working that way at the moment. Once it raises the front right the steering is normal again. |
Sat Apr 09 2016 12:15pm |
I imagine so.
Not sure really. Could be something geometrical? Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Sat Apr 09 2016 12:18pm |
Who knows, there might actually be an obstacle there It was good as gold during the test drive though, so I'm pretty sure it'll be a minor thing related to the ARB work.
Sat Apr 09 2016 12:25pm |
Oh and he's sorting me a new key out as well, which will be useful as remote locking only works when the stars are aligned correctly. |
Sat Apr 09 2016 12:28pm |
Land rover tech support have sent the workshop some updated calibration files, apparently, so the car should be back tomorrow with a new key fob. All related to the calibration, apparently. Fingers crossed. |
Mon Apr 11 2016 3:32pm |
Power steering pump being done too, that'll be the steering resistance then! They couldn't reproduce the steering fault all day until they dropped it back to my house, it's intermittent so I'm glad it happened to them in time.
Tue Apr 12 2016 5:11pm |
Turns out some of it was the pump but they've also replaced something to do with a fluid joint. Probably got that completely wrong, it might well be the ace rail that sometimes leaks. Saw another post on this forum about ace rails and the symptoms sounded similar. I'll find out tomorrow when it's finally ready. The steering problems have gone away, and no faults being logged but they're going to drive it again in the morning to check nothing else surfaces. For now they've given me their E class cabriolet to drive round. Not a bad car, wouldn't choose one though. Doesn't do my post-op back and favours either. Nightmare to get in and out of! |
Wed Apr 13 2016 7:53pm |
Got it back just now. Feels like a new car. Much smoother to drive, steering easier, less bumpy. It was the dynamic response anti roll bar that needed doing, apparently. New key, calibrated, new height sensor, power steering pump as well. |
Thu Apr 14 2016 5:11pm |
certainly got your moneys worth from the dealer. They sound like a good garage. |
Fri Apr 15 2016 9:46am |
Yeah they are good chaps. The list of work they've done to it is mammoth now, and it's driving like a dream only issue I've got with the car is no Bluetooth audio! But aux will do. |
Fri Apr 15 2016 11:08am |
If you don't have Logic 7 you can get this kit:
Fri Apr 15 2016 11:31am |
