Home > General > Wet carpet
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Wet carpet
Been away for the weekend and left the car straddled on about a 25 degree slope. Opened the drivers door today and water almost gushed out of the drivers side footwell. Any ideas? It has a sunroof? Is clearing the sunroof drain an easy job?
Thanks
Neil
Post #491903 Sun Mar 27 2016 3:42pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
Lots of posts on this if you search - sunroof drain is first thing to check/fix - but could be intake under the cowl you need to modify with duct tape due to bad design ... Btw Mine is doing the same - I have just not got around to fixing yet and rainy season is over in California
Post #491910 Sun Mar 27 2016 5:08pm
Paddi
Check out this TSB on the four most likely sources of the leak and how to tackle them:
http://www.rrsport.co.uk/gallery/albums/us...%29%20.pdf 2008 MY Java Black TDV8 HSE
Post #491919 Sun Mar 27 2016 6:18pm
Bladeboy
Thank you
Post #491935 Sun Mar 27 2016 8:35pm
