![]() | Home > General > Wet carpet |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
Lots of posts on this if you search - sunroof drain is first thing to check/fix - but could be intake under the cowl you need to modify with duct tape due to bad design ... Btw Mine is doing the same - I have just not got around to fixing yet and rainy season is over in California |
Check out this TSB on the four most likely sources of the leak and how to tackle them:
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
Thank you |
