Home > Maintenance & Modifications > Wheel bearing and front drive shaft required.
Martin0711
As the title suggests,
I'm looking for a front wheel bearing and drive shaft for a 2006 2.7 TDV6 Sport.
I replaced the drivers side wheel bearing last week due to noise and excessive play. Was a pretty straight forward job to be honest and i never thought about checking the passenger side.
Then today whilst out and about i heard a grinding noise from the passenger side wheel bearing. Jacked the car up and rightly so the wheel bearing is knackered. Im pretty sure someone has had this hub apart recently as the hub nut indent was chewed up and threads on the drive shaft are pretty badly gouged and the hub retaining bolts weren't exactly tight.
I need to get parts ASAP and get back on the road as soon as possible as i have got a race meeting this week and need the range rover for towing.
Where do you guys recommend for reasonable prices and fast/efficient delivery to Scottish Highlands.
Any information would be appreciated
Post #489323 Sun Feb 28 2016 7:41pm
TomTerrain
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
I've just bought a few bits from Paddocks, good price and it arrived quite quickly, not sure about Scotland though. Only downside is they don't seem to have that many of parts for the RRS 2006 Java Black HST Supercharged
Post #489327 Sun Feb 28 2016 8:02pm
Advanced Factors on this forum. Always been quick and good prices. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #489330 Sun Feb 28 2016 8:15pm
Disco_Mikey
If you buy a new driveshaft, you will also need a new hub nut. The thread was changed at some point, and the old nit will no longer fit Thumbs Up
Been caught out with that before Evil or Very Mad
Post #489332 Sun Feb 28 2016 8:17pm
TomTerrain
I was caught out with a different sized hub nut on my Discovery TD5 when trying to change the hub at the side of the road miles away from home. Had to go into a nearby garage and beg to borrow a socket! Embarassed 2006 Java Black HST Supercharged
Post #489336 Sun Feb 28 2016 8:25pm
Martin0711
Thanks for the info guys Thumbs Up
I'll give advanced factors a call first thing tomorrow and get something sorted out.
Will the hub nut that is supplied with the wheel bearing not be the same thread as the new drive shaft ??
Post #489348 Sun Feb 28 2016 9:21pm
Disco_Mikey
No, the one supplied with the new bearing is the old thread
Post #489377 Mon Feb 29 2016 8:03am
TomTerrain
When changing the hub, after the bolts are taken out, can you just pull it off, or is it a press fit? seems to be conflicting info when ive looked into doing it! 2006 Java Black HST Supercharged
Post #489767 Wed Mar 02 2016 9:20pm
Martin0711
Are you hoping to replace the bearing assembly ??
After the 4 x bearing assembly bolts and the drive shaft nut is removed push back the drive shaft from the hub.
Then give the wheel flange a good few blows with your favourite persuasion tool of choice. It will eventually start to move.
Post #489771 Wed Mar 02 2016 9:38pm
TomTerrain
yeah, its just one sealed unit isnt it?
ahh okay, thanks, so its just a case of gently persuading it out! Twisted Evil 2006 Java Black HST Supercharged
Post #489774 Wed Mar 02 2016 9:54pm
Martin0711
As long as the drive shaft has been pushed back then yes it just needs a good whacking.
The bearing i did last week took a good beating to get apart.
Post #489778 Wed Mar 02 2016 10:03pm
TomTerrain
Is a hammer easy enough, or would a slide hammer be a worthwhile investment? 2006 Java Black HST Supercharged
Post #489780 Wed Mar 02 2016 10:15pm
Martin0711
A hamer was good enough for me mate. Id imagine a good quality heavy duty slide hammer would make it a little easier Thumbs Up
Post #489783 Wed Mar 02 2016 10:20pm
TomTerrain
Thanks for the info Martin, i'll get myself a pair of hubs ordered now! Thumbs Up 2006 Java Black HST Supercharged
Post #489784 Wed Mar 02 2016 10:21pm
Martin0711
No problem.
I ordered my bearings from Advance Factors. They are a sponsor on this site Thumbs Up
Post #489787 Wed Mar 02 2016 10:33pm
