![]() | Home > Technical > Fixed.Almost no response on throttle when cold RRS 2.7 2006. |
41664166@online.no Member Since: 01 May 2015 Location: Moss Posts: 128 ![]() ![]() ![]() |
Hello again
Anyone have a idea her ??? |
Could be a seized turbo actuator. You should find threads on freeing it with a search on Disco3. |
Can`t find info about it |
Few threads here:
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 ![]() ![]() ![]() |
I had that issue on a Alfa I used to own.
Now it is fixed
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
I have 2 Alfas and 2 LR's. No such problems with the Alfas, but I have this problem with my Freelander 2. Wonder if I would dare take a risk by spraying the MAF with switch cleaner...........a new FL2 MAF sensor is well over £130. |
I cleaned one once with an ultrasonic cleaner (connector out of the cleaning solution) which worked great.
That's great you sorted it. RRS HSE with a few extras & a 2013 RRS Autobiography |
