Home > General > Brake torque setting
Ned
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Fuji White
Please can any one tell me the torque settings for for the brake calliper and calliper carrier I have looked at Bodeys writ up (great by the way) but I can't seem to find the answer my car RRS AB my2012 many thanks and enjoy your weekend.
Post #482838 Fri Dec 18 2015 9:45pm
I think you will find Bodsy's figures are right.
Calliper Carrier 275Nm.
Calliper to Carrier 35Nm.
Disc Retaining Screws 35Nm.
Bleed Screw 10Nm.
Brake Hose Union 32Nm.
If you have 6 pot Brembo's the bleed screw is 19Nm and Brake pad centre bolt 30Nm. Obvioulsy with the Brembos you do not have the calliper to carrier as the calliper is bolted direct to the knuckle.
Post #482841 Fri Dec 18 2015 10:50pm
Ned
Thanks for your time is that 275nm for both front and rear carriers ?
Post #482842 Fri Dec 18 2015 11:00pm
No the Rears would appear to be 115Nm.
Post #482843 Fri Dec 18 2015 11:13pm
Bodsy
Site Sponsor
The disk retaining screw has been reduced to 20nm. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #482844 Fri Dec 18 2015 11:46pm
Ned
Thanks for your reply, that a substantial drop in torque for the rear carrier!
Post #482879 Sat Dec 19 2015 5:38pm
