Home > Maintenance & Modifications > 2010 RRS Rear Spoiler Removal
gavlar2206
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
I'm really struggling to remove the spoiler!
I've followed various guides and videos but it still won't remove!
All the guides and videos are for the pre-facelift model Range Rover is there any difference?
I've removed the two torx bits with the top half of the boot open and then x3 13mm bolts with the boot open.
But it still won't move, it's loose but I'm frightened I will break it as it feels like there is still something holding it in place.
I hope someone can help me!
Thanks in advance
Gav
Post #478294 Fri Oct 30 2015 2:27pm
gavlar2206
I'm going to attempt this again today!
Anyone encountered a similar problem?
Post #479124 Sun Nov 08 2015 11:44am
I have removed a couple of these spoilers and I'm sure that is all that attaches them Two Torx screws and Three 8mm Nut's.
Rear Washer Pipe, Brake Light and Rev Camera Lead if fitted.
Although not heavy it easier with Two People as you need to be careful when you lift it not to scratch the roof with the Three 8mm mounting studs.
Post #479126 Sun Nov 08 2015 12:29pm
gavlar2206
I've finally managed to do it!
The spoiler was quite stiff to get off and I was worried that i would break something, I now have a fully functional reversing camera!
Thanks
Post #480812 Tue Nov 24 2015 12:45pm
