Home > General > can anyone edit my CFF (near bristol) |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
It won't work unless you also put the screen in FFRR mode (by cutting a wire on the back), but this will screw up bluetooth etc.
Fri Aug 07 2015 9:35am |
lamb190 Member Since: 12 Jun 2015 Location: bristol Posts: 80 |
i was aware i would have to cut the middle wire to make it full fat mode.
Fri Aug 07 2015 12:17pm |
http://www.disco3.co.uk/wiki/Hidden_Menu
Fri Aug 07 2015 12:24pm |
ok so go into the rear view camera via video imputs test using the secret button/code.
Fri Aug 07 2015 12:45pm |
in "vehicle signals" in the hidden diagnostics menu, one of the options is reverse gear... this is currently "off" would turning it "on" get rear cam going?
Fri Aug 07 2015 12:48pm |
No, unfortunately there's no way of using that method automatically. The reverse gear is just an indicator, rather than a selectable option. Visiting from DISCO3.CO.UK
Fri Aug 07 2015 12:51pm |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Let me understand this correctly - even if I edited the Car Configuration File to enable the "Rear View Camera" option so it would show as "on" in the video sources test menu, the car will not display the feed from a camera connected to the brown input on the rear of the radio unit? Regards etc.,
Fri Aug 07 2015 2:53pm |
The video will display via the hidden menu regardless of the CCF setting. If the CCF is changed, it will still not show automatically, unless the screen is in FF mode. Visiting from DISCO3.CO.UK
Fri Aug 07 2015 3:00pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
lamb190
Fri Aug 07 2015 3:02pm |
Syd, his profile is already filled in? 2006 4.4 V8 HSE. Visiting from DISCO3.CO.UK
Fri Aug 07 2015 3:06pm |
Thanks. Damn. Which GVIF interface is the one that allows "factory" buttons on the touchscreen for DVD, TV etc? I believe it has been mentioned in the (excellent) pdf GVIF installation walk-through on Disco3.co.uk, but no name has been given? Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Fri Aug 07 2015 3:28pm |
I believe NavTV is the one you're thinking of: http://www.nav.tv/products/land-rover-rang...nav-inrr05
Fri Aug 07 2015 3:46pm |
Sorry, I should have said Signature...... Still worth joining the Disco 3 Forum though In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
Fri Aug 07 2015 3:47pm |
Of course; all RRSport members are welcome on the D3 forum.
Fri Aug 07 2015 3:51pm |
