Home > General > can anyone edit my CFF (near bristol)
lamb190
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Rimini Red
im after getting my CFF function activated so i can run a reverse camera via my denso screen (already have the adaptor cable)
does anyone have an IID tool near bristol that can do this?
cheers
spence
Post #469757 Fri Aug 07 2015 9:26am
Lost for Words
It won't work unless you also put the screen in FFRR mode (by cutting a wire on the back), but this will screw up bluetooth etc. Sad
The alternatives are:
A) Use the secret menu to access the feed manually.
B) Fit a GVIF interface.
Thumbs Up Visiting from DISCO3.CO.UK
Post #469758 Fri Aug 07 2015 9:35am
lamb190
i was aware i would have to cut the middle wire to make it full fat mode.
can you tell me more about the hidden menu option?
for the cost of gvif interface i could get a fantastic headunit and put camera into that. but i dont fancy taking current headunit appart to get top screen working.
cheers
Post #469763 Fri Aug 07 2015 12:17pm
Lost for Words
http://www.disco3.co.uk/wiki/Hidden_Menu Thumbs Up
It's a shame about the side effects of the FF mode, as many have therefore found it to be unviable. Visiting from DISCO3.CO.UK
Post #469764 Fri Aug 07 2015 12:24pm
lamb190
ok so go into the rear view camera via video imputs test using the secret button/code.
i havnt fitted a camera yet... but i have the cable. is there a way i can get camera to work via this screen system when in reverse? or do i have to manually hack it each time?
Post #469766 Fri Aug 07 2015 12:45pm
lamb190
in "vehicle signals" in the hidden diagnostics menu, one of the options is reverse gear... this is currently "off" would turning it "on" get rear cam going?
cant seem to turn in on..think it reading gear selector position
Post #469767 Fri Aug 07 2015 12:48pm
Lost for Words
No, unfortunately there's no way of using that method automatically. The reverse gear is just an indicator, rather than a selectable option. Thumbs Up Visiting from DISCO3.CO.UK
Post #469769 Fri Aug 07 2015 12:51pm
TheWojtek
Let me understand this correctly - even if I edited the Car Configuration File to enable the "Rear View Camera" option so it would show as "on" in the video sources test menu, the car will not display the feed from a camera connected to the brown input on the rear of the radio unit? Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #469774 Fri Aug 07 2015 2:53pm
Lost for Words
The video will display via the hidden menu regardless of the CCF setting. If the CCF is changed, it will still not show automatically, unless the screen is in FF mode. Thumbs Up Visiting from DISCO3.CO.UK
Post #469775 Fri Aug 07 2015 3:00pm
SRE
Spain
lamb190
It may pay you to add a few things to your profile/signature.
MY
Petrol/Diesel etc
Also for these types of mods the Disco 3 Forum is pretty good. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #469776 Fri Aug 07 2015 3:02pm
Lost for Words
Syd, his profile is already filled in? Confused 2006 4.4 V8 HSE. Wink Visiting from DISCO3.CO.UK
Post #469777 Fri Aug 07 2015 3:06pm
TheWojtek
Thanks.
Damn.
Which GVIF interface is the one that allows "factory" buttons on the touchscreen for DVD, TV etc? I believe it has been mentioned in the (excellent) pdf GVIF installation walk-through on Disco3.co.uk, but no name has been given? Regards etc.,
Wojtek
Post #469779 Fri Aug 07 2015 3:28pm
Lost for Words
I believe NavTV is the one you're thinking of: http://www.nav.tv/products/land-rover-rang...nav-inrr05
Another standard GVIF option: http://www.hids4u.co.uk/land-rover-discove...creen.html
Note that the factory TV and DVD systems can be retro-fitted and will work, though not on the move, which is another benefit of a the NavTV/GVIF option. Thumbs Up Visiting from DISCO3.CO.UK
Post #469784 Fri Aug 07 2015 3:46pm
SRE
Spain
Embarassed Embarassed Sorry, I should have said Signature...... Whistle Whistle
Still worth joining the Disco 3 Forum though Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #469785 Fri Aug 07 2015 3:47pm
Lost for Words
Of course; all RRSport members are welcome on the D3 forum. Thumbs Up
(We'll get the rotten tomatoes ready... Mr. Green ) Visiting from DISCO3.CO.UK
Post #469786 Fri Aug 07 2015 3:51pm
